Quadrajet troubles
Old Mar 27, 2026 | 10:15 PM
Piersonpie's Avatar
Piersonpie
Sounds like a great improvement! Regarding timing, it does sound a bit backwards that changing your vacuum advance to a ported spot made the engine run smoother. Usually going from 12 degrees to whatever it’s adding would make it better. What are you reading at idle timing wise with the VA plugged in?
Old Mar 28, 2026 | 08:22 AM
jsbowman6's Avatar
jsbowman6
It is 12 degrees, plugged in or not at idle.
