Radiator/Shroud seals...
Old Mar 23, 2026 | 06:11 AM
CecilVette's Avatar
CecilVette
Cruising
Default Radiator/Shroud seals...
Rebuilding my early 1976 L48 and wish to set the cooling system up as stock since from what I read it seems like cooling system works best as stock. I want to buy a seal kit but every major corvette dealer ( Ecklers, Top Flight, ect ) tells me it is out of stock for a early 1976 without air conditioner. Now I can get the kit for an early 76 with air conditioning and want to ask if there is that much difference that the kit for the AC would not work? I have read that I could get foam from the local hardware for a fraction of the price but I would rather just buy the kit and be done with it. So is the AC kit doable before I spent the coin? Thanks in advance for any responses.
Old Mar 23, 2026 | 07:55 AM
Alan 71's Avatar
Alan 71
Hello,
Have you checked with Dr.Rebuild.
He can be difficult to deal with but generally has a very good supply of 'soft parts'.
Again... be prepared for a bit of an 'experience'!!
Regards.....
Here's an example:
Buy it Now - Dr REBUILD's Corvette Parts ----------- - MODEL -----------------------------
Part #
Y Early 76 except L-82 or AC Radiator Seal 5 Piece Set Includes LH and RH upper horizontal seals with pre-punched mounting holes, lower horizontal seal, plus LH vertical side seal with 2 pre-punched mounting holes and RH vertical side seal with 3 pre-punched mounting holes. All have PSA. Uses 7 PIF
Old Mar 23, 2026 | 08:47 AM
bmotojoe's Avatar
bmotojoe
I agree with the above about that vendor
First watch Seinfeld Season 7 episode 6...
There are seals on ebay you might look at...
Link: https://www.ebay.com/sch/i.html?_nkw...eals&_osacat=0
Old Mar 23, 2026 | 02:11 PM
ctmccloskey's Avatar
ctmccloskey
Come on, lets cut the guy some slack. DocRebuild sells some of the best replacement parts you can get and I have never had one fall short. His vacuum hose set is 30+ old, looking new and working great. They have lasted longer than the GM factory hoses did on my 1968 C3.
I would be a tough person to be around after dealing with some of the Corvette folks I have met at Corvettes@Carlisle. If you treat him nicely then you will likely get that in return is what normally works with most people.
Old Mar 23, 2026 | 02:25 PM
CecilVette's Avatar
CecilVette
Cruising
Thanks for turning me onto Dr Rebuild, just ordered the correct seals......as far as the experiance goes all I can say is WOW.
Old Mar 23, 2026 | 04:17 PM
theandies's Avatar
theandies
"Dr. Rebuild - WTF do you want?"
Old Mar 23, 2026 | 04:41 PM
Alan 71's Avatar
Alan 71
Hello ctm,
I'm a firm believer in Dr.R and what he sells or I wouldn't have suggested him to CV.
Regards.......
Old Mar 26, 2026 | 07:56 AM
ctmccloskey
It is good that DocRebuild has so many good friends! He has me for life...
Thanks Alan for your recommending the best sources to the forum members. You do a great job there Alan!
To Radiator/Shroud seals...
