72 tilt column question
Old Apr 14, 2026 | 05:22 PM
JRS 94's Avatar
JRS 94
Default 72 tilt column question
Probably asked a hundred times. Does the 1972 tilt / tele column have a key position counterclockwise from "lock"? Mine clicks 2 times clockwise, then I get start.
Old Apr 14, 2026 | 08:42 PM
kansas123's Avatar
kansas123
Yes it does
Old Apr 14, 2026 | 10:27 PM
JRS 94's Avatar
JRS 94
Originally Posted by kansas123
Yes it does
Bummer, that means mine is broken. Thanks for the reply.
Old Apr 15, 2026 | 06:58 AM
sleepchamber's Avatar
sleepchamber
Mine will turn backwards to the acc position.....sometimes. 😔
Old Apr 15, 2026 | 07:32 AM
JRS 94's Avatar
JRS 94
Thanks, I wanted to be sure it was supposed to do that before I chase it and make it worse. Im goimg to try the cable that connects to the trans and see if its related at all, then go from there. Does your steering wheel lock?
Old Apr 15, 2026 | 08:10 AM
sleepchamber
Yes the wheel locks. Everything else seems to work. I think the ignition cylinder is just worn out. It is 54 years old. I haven't figured out how to jiggle it to get it to turn backwards which makes me think something just isnt turning as it should.
Old Apr 18, 2026 | 07:16 PM
JRS 94's Avatar
JRS 94
I checked the cable and the positioner on the column, once in awhile the wheel will lock but I never get back to accessory position, the tumbler sticks some even with the forward positions sometimes. Do I need a new tumbler or it it something in the column? or bad keys, Any ideas?
Old Apr 19, 2026 | 07:43 AM
sleepchamber
My last car started getting hard to turn the ignition and felt clunky. Didn't take long for it to stop turning completely. If it were me i would replace the ignition lock assembly now.
Old Apr 19, 2026 | 09:10 AM
JRS 94's Avatar
JRS 94
Agreed. That's going to move up the list. I'm doing control arm bushings now.
To 72 tilt column question
