Freeze plug leaking....
Old May 2, 2026 | 06:45 PM
CecilVette's Avatar
CecilVette
Cruising
Default Freeze plug leaking....
Just dropped a fresh built 383 in my 76, got everything lined up, filled with antifreeze and was a few days from fire up when I noticed fluid on the floor. Freeze plug by starter is leaking. Now I dropped 1k at the machine shop to have the block redone including new Freeze plugs, pressure test, bore, and mag. I really don't want to yank this engine again but I have never replced a freeze plug. Is it difficult to get the old plug out and what is the best way to do this? I seem to have enough working room, any advice would be appreciated.
Popular Reply
May 3, 2026, 01:07 PM
CecilVette's Avatar
CecilVette
Cruising
Thanks for the video, plug came out just as shown. I ordered a new brass plug and have plenty room to tap in with sealant. Second time this machine shop has given me back a leaky block so it is safe to assume we are about done.
Old May 2, 2026 | 08:27 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
No they are not hard to get out. Small hole. Pry out or thread in a dent puller and pull.
Tap in a new one carefully making certain it goes in square. Perhaps a little sealer like Threebond 1104 just for insurance.
Old May 2, 2026 | 08:50 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Here's a quick segment on tapping and prying them out from Jim's Automotive Machine Shop Inc. - a father / son business. Jump to 46:40 to see Jim removing the plugs.
Old May 3, 2026 | 09:30 AM
pltmgr's Avatar
pltmgr
I think the machine shop that did the work should replace the leaking freeze plug at no charge.
Old May 3, 2026 | 01:07 PM
CecilVette's Avatar
CecilVette
Cruising
Old May 3, 2026 | 07:19 PM
4-vettes's Avatar
4-vettes
I guess so. ... just be thankful it was one you could get at.
Old May 3, 2026 | 07:45 PM
Rebelyell's Avatar
Rebelyell
Default belt & suspenders GM P/N 12378255
Suggest you hedge your bets; also Dose your cooling system with GM Cooling System Seal Tabs.
available at local GM dealer parts counter; VERY old, reliable "bromide"
Chevrolet Performance 12378255 - Chevrolet Performance Coolant System Seal Tablets
https://www.summitracing.com/parts/nal-12378255
GM P/N 12378255
Old May 7, 2026 | 09:23 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Use Indian head gasket Shellac on Brass Freeze plugs from a leaky hole.......you are upside down under the car and you only want to do this once.....
Jebby
Old May 7, 2026 | 08:32 PM
drwet's Avatar
drwet
I have used Permatex Aviation Form-a-Gasket with good success.
To Freeze plug leaking....
