1971 LS5 Valve cover gaskets
Probably a stupid question but when putting the valve covers back on do you tighten until snug or do they need to be torqued?
TIA
The 454 valve cover bolts require very little torque.
8-10 INCH lb.
Be sure the triangular retainers are in place to help keep the bolt from deforming the valve cover.
It's easy to break or strip the bolt. Be careful.
Regards.....
My torque process is to start all the bolts in the threads but only focus on the bottom row. Snug the 1st up, then the 3rd, then the 2nd, then the 4th. Go back to the 1st and do the sequence again. Repeat once more. I use a small 1/4" drive socket & extension and am just using wrist rotation, not full arm strength to tighten them down. After all of the bottom row are snug such that they don't easily turn any more, I tighten the top row. A sequential pattern isn't as important here, but I do middle, front, rear with one repeat. I also check them whenever I'm doing any work on the engine, just to snug up if needed. I've used this method over many years on both of my BB engines and don't have any leaks from the covers.
https://www.summitracing.com/parts/CGT-C5975-2
They have a steel core with rubber on both sides but more importantly they have steel sleeves in all the bolt holes so you can tighten the bolts without crushing the gasket. For the first time since I got the car 30 years ago I have no leaks.
