1973 Removable rear window template -
Plan B is to replace the entire frame with a plastic replacement attaching the hardware that holds it directly to the plastic.
Thanks in advance,
Frank
I could be wrong but 72 was the last year for the removable rear window glass.
Many people have modified their 73’s and installed the 72 and earlier removable glass so it is possible but the entire frames and hardware are different.
Does the 77's rear deck and halo still have the fiberglass configuration to accept the gasket, locks, and lower pegs needed to install the complete removable window?
Regards....
Can you use the frame you have to make the template?
