Suspension pic
Old Mar 30, 2003 | 07:46 AM
foundvettelifeisgood's Avatar
Default Suspension pic
Old Mar 30, 2003 | 09:02 AM
71stingraybigblock's Avatar
71stingraybigblock
Default Re: Suspension pic (foundvettelifeisgood)
Looks very good! VB makes a wonderful bolt-in kit. I have been running mine for about 1 1/2 years now and love it.
Old Mar 30, 2003 | 09:09 AM
PatsLs1vette's Avatar
PatsLs1vette
Hows it ride and can it be adjusted from side to side?Like a rear leaf can.
Old Mar 30, 2003 | 09:11 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
:thumbs: That new suspension is looking mighty fine :cool:
Old Mar 30, 2003 | 10:25 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Default Re: Suspension pic (patsnitrovette)
I have it on my 80 and love it. I can be adjusted on both side. If your thinking about getting it, measure from the top of the wheel well to the ground on both side, so when you put it in you can adjust it to original ride hieght. :thumbs:
Old Mar 30, 2003 | 11:09 AM
Default Re: Suspension pic (Van Steel)
Ride height is a simple adjustment. They recommend initial set up leaving 1.5 inches of bolt. After you drive it around the block to settle everything in, you'll end up lowering it to achieve the stock stance of 27". The 8" end bolts in the front are the same part number as the 8" end bolts in the rear. Same adjustment with each side independent.
The spring mounting system has 4 settings that I would describe as:
1) taunt/great
2) hard/what have I done to my car
3) real hard/how could anyone bear this
4) real real hard/track only?
I intially went for the second setting and backed it down to the first. I honestly haven't tried 3 or 4. Setting 2 might be ok on very smooth roads, but was not enjoyable on anything with a ripple.
I really like the system, and it was a lot of fun to install. No regrets here, except that I didn't do the trailing arms or differential "while I was at it." Next winter. :smash:
Old Mar 30, 2003 | 11:21 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I hate dial-up! :cuss It took over 5 min to load that one pic. :mad
Looks good Jay. :yesnod: What's next? A BB??
[Modified by 1970 Stingray, 2:47 PM 3/30/2003]
Old Mar 30, 2003 | 11:26 AM
FASGLAS's Avatar
FASGLAS
CI 4-5-6-7-8-9-10-11 Vet
St. Jude Donor '06-'07-'08-'09
:thumbs: :cool:
Old Mar 30, 2003 | 11:29 AM
mrvette's Avatar
mrvette
Found, please do me a favor there, measure the tie rods from grease fitting to grease fitting....pivot centers.....need the length each side...thanks...
GENE
Old Mar 30, 2003 | 11:44 AM
PatsLs1vette
Default Re: Suspension pic (mrvette)
ok thanks ill have to look into it,since i have to do my front suspension over anyway.
[Modified by patsnitrovette, 10:40 AM 4/5/2003]
Old Apr 5, 2003 | 09:46 AM
Gene,
Sorry to leave you hanging. Passenger side looks to be 14 5/8 with driver side at about 14 7/8. Both of these are +/- 1/8th.
:cheers:
Old Apr 5, 2003 | 03:21 PM
timbo79's Avatar
timbo79
Looks good. I am looking at somewhat of the same set up. It looks as though you did the conversion.. straight shot in pic. Did you repace all the control arms as well, or just the spring conversion
How much lower than stock can you lower it? At least 1-2"?
It looks great!! :flag
Old Apr 5, 2003 | 04:12 PM
Default Re: Suspension pic (timbo79)
Timbo--Thanks. I did the full upper and lower A-arm conversion. The car is at stock height according to the assembly manual, which is roughly 27 inches.
:cheers:
Old Apr 5, 2003 | 04:42 PM
DMONSVETTE's Avatar
DMONSVETTE
Very nice, thanks for sharing the pics :cheers: :thumbs: :seeya
Old Apr 5, 2003 | 05:16 PM
groovyjay's Avatar
groovyjay
Looks very good man, can't wait til I get mine on the road and try out how it drives now with the new VBP set up. :steering:
To Suspension pic
