Need some problem solving ideas....
Old Apr 19, 2003 | 09:44 PM
Metal Wulf's Avatar
Metal Wulf
Default Need some problem solving ideas....
I have an emblem that I need the threaded studs to be about 2 inches longer. I need ideas on making them longer, and be stong enough to withstand extreme vibrations over long periods of time :D
Old Apr 19, 2003 | 11:48 PM
wombvette's Avatar
wombvette
Default Re: Need some problem solving ideas.... (Metal_Wulf)
Yellow glue, good stuff, stick`em tight.
Old Apr 20, 2003 | 12:34 AM
1969c3mandy's Avatar
1969c3mandy
Default Re: Need some problem solving ideas.... (wombvette)
get the long threaded nuts with the big nut at the end. worked for me...
which emblem?
Old Apr 20, 2003 | 12:44 AM
Metal Wulf's Avatar
Metal Wulf
Default Re: Need some problem solving ideas.... (1969c3mandy)
which emblem?
I'll have to check those out... It's the gas door emblem, but it's not going on the gas door :jester
Old Apr 20, 2003 | 10:47 AM
Metal Wulf's Avatar
Metal Wulf
TTT
Old Apr 21, 2003 | 12:01 AM
Metal Wulf's Avatar
Metal Wulf
back to the top...
Old Apr 21, 2003 | 12:49 AM
Rockn-Roll's Avatar
Rockn-Roll
Is the threaded stud a large enough diameter to say drill out 1/64" and then tap it to like 22 threads per inch and install a 2" long jewelers screw? Another possibility is to loop some thin wire around it and then thread it through your mounting surface and attach it somewhere inside...it may be sloppy this way, but a little rubber cement or something other surface contact glue would keep it from sliding around.
To Need some problem solving ideas....
