Gas Tank replacement..
Old Apr 22, 2003 | 09:07 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: Gas Tank replacement.. (Silvr77)
Not a bad job at all. Like stated above...be sure the tank is empty. there is always a "little" gas left so be carefull. I recommend replacing the tank cushion material that goes between the tank and crossmember. That stuff rots or falls out and can cause holes by the banging of tank to support. That's how I got my hole!!!! While your in there....how about new rubber fuel lines....sending unit...paint the support...new straps...stainless bolts???? Heck, I didn't want to do that again so I replaced everything along with the tank!!!!
Good Luck
Eddie
I will check and see what needs to be replaced... The support etc. doewn't look to be in bad shape but I might be wrong...
