Astro Vent ????
Old Apr 22, 2003 | 05:42 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Astro Vent ????
Welll I finally have a set of Astro Vent doors that I think is working correctly. I guess the previous owner must have disconnected everything and hoped it would make the car run better.
This is what I know about how MY Astro Vent works. Let me know if this is correct.
With the car running,
1. All the heat and vent controls off the doors are opened.
2. Vent controls closed the doors are opened.
3. With the rotary heat, de-ice, de-fog switch in any position the doors are opened.
4. When you select any temp/heat setting the door goes closed.
I hope this is correct because none of it has worked correctly since I have had the car. Let me know if any of you guys works the same way or if it is not working correctly. :thumbs:
[Modified by Eddie 70, 6:35 PM 4/22/2003]
Old Apr 22, 2003 | 10:08 PM
Eddie 70's Avatar
Eddie 70
Default Re: Astro Vent ???? (Eddie 70)
TTT
Old Apr 23, 2003 | 11:27 AM
Cookwithvette's Avatar
Cookwithvette
I am interested in knowing too.
TTT
Old Apr 23, 2003 | 03:05 PM
Surfer69's Avatar
Surfer69
That sounds about right. When heater is off, they should be open. When dial is set to anything they should shut. That's how mine works.
Old Apr 24, 2003 | 10:46 PM
Juliet's Avatar
Juliet
Default Re: Astro Vent ???? (Surfer69)
I recall reading a description of the operation of the Astro-Vent system somewhere, but I'll be damned if I can remember where. :D I have AC so get the blockoff plates in the rear, not the real Astro Vent. ;) I saw it in one of three places - The owner's manual - The GM Chassis Service Manual - or the NCRS Operations Manual. ~Juliet
Old Apr 25, 2003 | 02:20 AM
xelor98's Avatar
xelor98
As I recall the Astro Vent system on my 69 worked mainly for fresh air circulation. If anything is turned on the doors close, otherwise they are open. Back in 68/69 this was supposed to be a big deal to always have fresh air in car without the wind wings. (Remember those)?
:rolleyes: :rolleyes:
Old Apr 25, 2003 | 08:42 AM
Eddie 70's Avatar
Eddie 70
Default Re: Astro Vent ???? (xelor98)
Juliet hit the nail on the head. I went and looked in my 1970 owners manual and on page 28, for those that may be following this, it says,
-Whenever the heater temperatur contorl is moved toward the "Hot" position, the rear deck air exhaust doors close to retain teh heated air in the vehicle.
So there is my answer and now I understand what that manual is for now. Thanks for all the help.
:party:
[Modified by Eddie 70, 9:38 AM 4/25/2003]
Old Apr 25, 2003 | 08:48 AM
carl a's Avatar
carl a
does anyony have a picture where theseDOORS are located?- do you mean the grates on the rear deck by the rear window?
Old Apr 25, 2003 | 09:03 AM
Eddie 70's Avatar
Eddie 70
Default Re: Astro Vent ???? (carl a)
Carl, you are correct, this is where the vents are located. If you look at the back wall in your car you should see these vents, if your car is not equipped with air.
Old Apr 25, 2003 | 09:15 AM
Corvettes White's Avatar
Corvettes White
Got Vents working? Now you can be very :cool:
:D George
Old Apr 25, 2003 | 09:24 AM
Juliet's Avatar
Juliet
So there is my answer and now I understand what RTFM really means. Thanks for all the help.
Gee, and I thought I was being pretty nice with my reply. :lol: :lolg:
To Astro Vent ????
