Speedometer question
Old Apr 24, 2003 | 02:55 PM
ndirishr1's Avatar
ndirishr1
Default Speedometer question
I changed my stock 3:36 on my '68 327 4 speed to a 4:11. Would anyone know which tooth speedometer gear would be in my tranny for the 3:36 and what I need to change it to for the 4:11? :confused:
Old Apr 24, 2003 | 03:36 PM
77Dream's Avatar
77Dream
Default Re: Speedometer question (ndirishr1)
I know this isnt the answer you are looking for but you can call a local transmission shop and ask them. I'm sure they would also be willing to sell you the part and they should have it in stock.
:cheers:
Old Apr 25, 2003 | 08:30 AM
ndirishr1's Avatar
ndirishr1
Default Re: Speedometer question (77Dream)
Thanks, I've tried that and I haven't found one that's any help yet.
Old Apr 25, 2003 | 08:37 AM
carl a's Avatar
carl a
i went by the speed the car was off--theres a rule of thumb my mechanic told me ( this was 3 yrs ago) every tooth was worth so many miles per hour .. i remrmber this is how i got mine as close as possible------carl
Old Apr 25, 2003 | 09:21 AM
Fevre's Avatar
Fevre
Default Re: Speedometer question (carl a)
I think ZIP used to have a chart in their catalog that gave a rule of them method using the MPH off and tooth count. You have determine your MPH off then pull the speedo adaptor and count the teeth.
Old Apr 25, 2003 | 09:27 AM
mrvette's Avatar
mrvette
count your teeth, the count SHOULD be on the gear itself....say it's 43t which is a typical marking......you would want 20% MORE teeth....or a 51 tooth gear in this example....you may have to change the gear on the tranny output shaft, OR the housing the speedo gear rides in.....or BOTH....
GENE
To Speedometer question
