69 Rear letters
Old Apr 24, 2003 | 01:46 PM
TR69's Avatar
TR69
Default 69 Rear letters
My 69 does not have the CORVETTE letters on the back and whoever did the body work before I got it filled them in. Does the letters come with a diagram of where/how they are spaced? I am not really thrilled about drilling holes in the new paint...Any ideas?
Old Apr 24, 2003 | 01:49 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: 69 Rear letters (TR69)
Ideas?? Yes :D
Old Apr 24, 2003 | 02:13 PM
pws69's Avatar
pws69
Sounds scary!
I would first look at the back side to see if you can still see all of the holes and if yes, then I would drill from the back with a VERY sharp drill at a fairly high speed, but very slow and controlled feed.
OR - do what GrandSportC3 has done!
Old Apr 24, 2003 | 02:15 PM
sb69coupe's Avatar
sb69coupe
Default Re: 69 Rear letters (pws69)
Agreed, look from the back side to see evidence of filler in the holes. Carefully scrape it all away off the back of the rear tail panel, then use a TINY drill bit to drill them out.
If your tail panel has been replaced with one that does not have holes pre-drilled, then you'll need a template. I got one from a fellow Corvette owner and used it to drill the holes in my panel. When I was finished with it I passed it on to ddecart, so you may want to see if he's able to pass it on to you if needed.
Shannon
Old Apr 24, 2003 | 02:25 PM
Surfer69's Avatar
Surfer69
Assembly Manual should show exact detailed locations.
Old Apr 24, 2003 | 02:30 PM
NHvette's Avatar
NHvette
My 70 has the letters currently removed.
I could make you a template from this. 70=69 ??
:seeya
Old Apr 24, 2003 | 05:42 PM
TR69's Avatar
TR69
Default Re: 69 Rear letters (NHvette)
Forgot about the possible marks on the inside of the rear end. I like GrandSportC3's idea...still gotta drill those holes. IM'd NHvette as I will cover all bases. Got an assembly manual but I do not feel comfortable with it...
thanks all... :hurray:
Old Apr 24, 2003 | 05:59 PM
R1234's Avatar
R1234
Hello,
My rear letter holes were filled in too. I shined a small flash light from the inside. The original holes lit up through the filler.
Old Apr 24, 2003 | 06:51 PM
foundvettelifeisgood's Avatar
Default Re: 69 Rear letters (68rdstr)
Just make sure you spell it right. :jester
Old Apr 24, 2003 | 06:59 PM
OkeeGuy's Avatar
OkeeGuy
if you decide to go with vinyl letters as Oliver did, let me know cause i can make you anything you want...
any letter style...
any size...
any color...
To 69 Rear letters
