Drip Drip Drip
Old Apr 29, 2003 | 02:10 PM
SCS Red80's Avatar
SCS Red80
St. Jude Donor '10, '13
Default Drip Drip Drip
Noticed recently that my rear end is leaking, (the Vettes) - I looked underneath and believe it is coming from the differential drain plug.
Question - is this just a simple drain plug like the oil pan (bolt / crush gasket washer) or is there something special back there. Also what's the best way to get under the car - ramps or jack up each side and use jack stands?
Old Apr 29, 2003 | 04:45 PM
jimvette999's Avatar
jimvette999
Default Re: Drip Drip Drip (SCS Red80)
It's a pipe thread, different from engine drain plug. Pop your doors and hood a little before jacking car up. They flex. Always use good jack stands (no cinder blocks) too. Either method of elevating car would work. Diff. fluid should be even with drain plug opening when full. Make sure to use posi-traction type fluid if yours is low.
Jim
Old Apr 29, 2003 | 10:33 PM
SCS Red80's Avatar
SCS Red80
Default Re: Drip Drip Drip (jimvette999)
Thanks for the info Jimvette, I'll give it a look tomorrow and see whats what.
Old Apr 30, 2003 | 06:47 AM
Fleetwood's Avatar
Fleetwood
It sound like one of the side seals is leaking or the drive shaft seal,generally the oil level is below the drain plug.
Old Apr 30, 2003 | 06:51 AM
groovyjay's Avatar
groovyjay
Jim
:iagree: And that is one :cool: car you got the Jim!
Old Apr 30, 2003 | 07:02 AM
Jvette73's Avatar
Jvette73
To insure a better seal on the drain plug you could wrap the plug with teflon tape before putting it back in. That way you wont have to crank the holy b'jeasus out of it to get it to seal.
Old Apr 30, 2003 | 08:17 AM
79VetteMike's Avatar
79VetteMike
We want to see more pics of your car jimvette999
Old Apr 30, 2003 | 08:27 AM
Ki m Le's Avatar
Ki m Le
Put it on the jack stand then remove the wheel for easy access. Using a 3/4" 12 points socket with a long extension and rachet to remove the plug.
To Drip Drip Drip
