Coil-spring rates
Old May 17, 2003 | 09:47 AM
Red69's Avatar
Red69
Default Coil-spring rates
I'm doing some front suspension work and was considering changing my springs as well. Does anyone know what the spring rates are for the OEM springs?
69 BB w/AC
69 BB wo/AC
69 F41
Thanks :flag
Old May 22, 2003 | 04:41 PM
l2vette's Avatar
l2vette
Default Re: Coil-spring rates (Red69)
Good question, I would like to know as well for my 72.
:cheers:
Old May 22, 2003 | 04:55 PM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
John,
Five different coil springs and two different leaf springs were used during the 1969 model year.
FRONT SPRINGS
350 (no A/C) - Part #3931823 - "HS" - 250 lbs/in
350 (with A/C) - Part #3931824 - "HT" - 264 lbs/in
427 (no A/C) - Part #3931825 - "HU" - 284 lbs/in
427 (with A/C) - Part #3931826 - "HV" - 325 lbs/in
F41 (all) - Part #3832518 - "EA" - 550 lbs/in
REAR SPRINGS
350/427 (except F41) - Part #3850839 - "EA" - 70 lbs/in (per side)
F41 (all) - Part #3828811 - "EB" - 152 lbs/in (per side)
The springs were actually chosen based on sprung curb weight, but it usually took the addition of air conditioning to require a change to the higher rate spring (which is why I listed it as "with a/c").
As far as 1972, I believe that the springs were identical in part number, broadcast code, and rate. If I remember correctly, the spring information is listed towards the front of the 1972 AIM (as it is in the 1969 AIM).
Regards,
Old May 22, 2003 | 08:26 PM
ndirishr1's Avatar
ndirishr1
Looks like you got your answer. I think my 327 '68 had 280#. I replaced them with 460# and Bilstien shocks. Rides great. You know the ol' shock test where you push down to bounce the front end and see how quick it recovers? Well I tried that and it didn't move! I thought, "oh oh, I think I've overdone things again!" Thankfully, it rides and handles great.
Old May 24, 2003 | 11:45 PM
Red69's Avatar
Red69
Default Re: Coil-spring rates (ndirishr1)
Thanks Roudy - thats some helpful info! :hurray:
To Coil-spring rates
