MSD 6AL users..where do you mount?
Old May 22, 2003 | 12:31 AM
LFZ's Avatar
LFZ
Default MSD 6AL users..where do you mount?
I got the MSD 6AL, and mounted behind the passenger side dash compartment right beside the guage cluster..it works fine other than when i stomp the gas, the Door agar light flashes, then goes off as i let off the accelerator...whats up with that and any other advice on mounting spots??
[Modified by REDSHARKONBOYDS, 11:31 PM 5/21/2003]
Old May 22, 2003 | 12:54 AM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Re: MSD 6AL users..where do you mount? (REDSHARKONBOYDS)
I don't know why the door ajar is affected, but I mounted mine on an aluminum bracket on the aft side of the passenger wheel well.
Old May 22, 2003 | 12:56 AM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
My questions would be....
What/where did you hook up the ignition & power sources?
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
I never heard of electric interference like that man. :eek: Best idea I've seen was MSD box mounted between wiper motors. Cool (temperature) location still covered by hood from rain. Though I'd saved that thread as a note but could not locate it - sorry. Maybe a search?
My guess something is wrong with your door switch or maybe lamp is grounding out. :seeya
Old May 22, 2003 | 08:09 AM
gdh's Avatar
gdh
Default Re: MSD 6AL users..where do you mount? (cardo0)
I mounted mine on the near the top of the driver side inner fender, away from road debris yet still getting cool air.
Old May 22, 2003 | 09:29 AM
curly's Avatar
curly
I mounted mine on driverside firewall. I was able to use screws and nuts on the other side, reach down through that screen vent.
Old May 22, 2003 | 10:06 AM
norvalwilhelm's Avatar
norvalwilhelm
I have no heater in my car so I blocked off the hole in the firewall and mounted 4 MSD units, the coil and a ford starter solenoid, and a whole bank of relays where the old heater was. By removing the dash section which is easy all my electronics are right there. They stay cool not being in the engine compartment, also stay clean and easy to get at.
I have had no problems and they have been there for years.
Old May 22, 2003 | 12:05 PM
crf311's Avatar
crf311
I put mine on the passanger side wheel well.
Old May 22, 2003 | 01:03 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: MSD 6AL users..where do you mount? (crf311)
Mine never had a windshield wiper washer tank so I put it where the tank used to be.
Old May 22, 2003 | 01:14 PM
NHvette's Avatar
NHvette
Default Re: MSD 6AL users..where do you mount? (tshort)
73ken73 has his mounted here: (note the fuel pressure guage location)
:seeya
Old May 22, 2003 | 03:16 PM
Marks69BB's Avatar
Marks69BB
Mine is mounted under the passenger seat. No one knows it's there and it is out of the elements.
Old May 22, 2003 | 03:34 PM
The Dude's Avatar
The Dude
Default Re: MSD 6AL users..where do you mount? (bgrice)
bgrice:
Like some of the others, I put my box on the inside of the passenger wheel well. I drew power and ground from the starter. That's the next best thing to a direct battery connection and that's what MSD recommends. Besides, it's conveniently located and why run a whole bunch more wire than you have to?
[EDIT] I see now you weren't asking where to put and how to wire YOUR MSD. But this is what I did with mine FWIW.
[Modified by The Dude, 12:43 PM 5/22/2003]
Old May 22, 2003 | 04:43 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Re: MSD 6AL users..where do you mount? (The Dude)
I have seen most as the Dude states. Makes sense to me.
Old May 23, 2003 | 06:59 AM
gotchashawn's Avatar
gotchashawn
good question . thx for da recomendations / opionions you forum members :flag
Old May 23, 2003 | 09:31 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: MSD 6AL users..where do you mount? (gotchashawn)
I have mine in the wiper valley/rain gutter or whatever it's called :lol:
Nice and cool out there and the rev limiter chip is siliconed in, just have to change it as a friend with good eyesight pointed out it is set at 8000RPM not 6000RPM I thought it was set at :eek:
To MSD 6AL users..where do you mount?
