O ring between caliper halves.
Old May 22, 2003 | 08:39 AM
adamdinat's Avatar
adamdinat
Default O ring between caliper halves.
Is there anything special about the oring between the caliper halves or can I just buy a standard O ring at the auto parts store? I assume these should be replaced every time you split the caliper. I have not seen these in any catalogs.
[Modified by adamdinat, 8:40 AM 5/22/2003]
Old May 22, 2003 | 08:41 AM
ImBatman's Avatar
ImBatman
Default Re: O ring between caliper halves. (adamdinat)
You should be fine as long as it is the same size.
Old May 22, 2003 | 09:34 AM
Matt Gruber's Avatar
Matt Gruber
i've re-used them up to 10 years so far. But one did not look good so i replaced that one.
To O ring between caliper halves.
