Crate Motors
Old May 22, 2003 | 11:32 PM
Sun King's Avatar
Sun King
Default Crate Motors
What's up with those ZZ's? Is that the next generation LS1? What's the pricing like?
Old May 22, 2003 | 11:40 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: Crate Motors (WS6TA01)
ZZ's are old tech and way over priced...
Old May 22, 2003 | 11:54 PM
80Xflags's Avatar
80Xflags
Default Re: Crate Motors (Metal Wulf)
If ZZ's are old tech and way over priced, what are the other options??? :confused:
:grouphug:
Sun King's Avatar
Sun King
Thanks,
I've got $$ burning a hole in my pockets and am wheighing my options. Even thinking about that 350/350...LS1 probably has too much electronics and I've got no CATS...I'm thinking I'd need to hook up an emmissions system on one. But the motor would kick A with the 4-spd...
ps. nice garage :cheers:
Old May 22, 2003 | 11:58 PM
Sun King's Avatar
Sun King
Default Re: Crate Motors (80Xflags)
There's several optional crates in the small block w/ various HP and options
Old May 23, 2003 | 12:06 AM
80Xflags's Avatar
80Xflags
Got any names, web links, or prices and performance stats? I was under the impression that the ZZ was the all-around best drop-it-in-and-go engine for the money. Then again, this is why it's always good to shop around and ask. :hat
Matt
Old May 23, 2003 | 12:14 AM
Shark Racer's Avatar
Shark Racer
Like Metal Wulf said, ZZs are "old tech".
The block/cam setup is "newer tech" than the blocks that came in our cars, as they have the nice 1 piece main seal and machined for hydraulic roller lifters. The heads are kinda poopy, but it's a good, reliable motor that makes good power. I like the ZZ4 because it uses hydraulic rollers, hence using the block as the base for my eventual buildup.
The ZZ4 is still based on the first gen small block chevy, LT1/4 is 2nd gen, LS1/6 is 3rd gen.
(The LT1/4 isn't TOO different from our cars, reverse flow and ignition setup being the biggest change... heads/cam still work similarly)
-Steve
Old May 23, 2003 | 12:16 AM
Sun King's Avatar
Sun King
I was checking them out at GM Goodwrench.com. Part #s galore, not much for stats though. That's why I was asking over here.. :confused:
Old May 23, 2003 | 12:25 AM
Metal Wulf's Avatar
Metal Wulf
do a search for "ZZ4" you'll find all the info you want to know about that engine.
http://forums.corvetteforum.com/zerosearch
Old May 23, 2003 | 01:00 AM
vssii58's Avatar
vssii58
I had a ZZ4 in my Vette. 350hp @ 5250rpm, 405ft lbs. A good lumpy idle still had vaccum for everything and ran like a bat out of hell. I ran mid 13's with a 700R4 and a 3.07 gear. I bought mine from jegs.com 3years ago for around $3200.00. That motor is now going in my sons s10 blazer.
Old May 23, 2003 | 01:28 AM
Michael Tucker's Avatar
Michael Tucker
WS6TA01,
try this 383. 500lb-ft @4200 rpm and 460 hp @ 5400 rpm
http://www.hotrod.com/hotrod/techarticles/66278
and i love my ZZ4! i drive it like a dawg and never keep up on the oil changes like i should. been waiting for the 572 but i hear they are only making 200 of them so i think i might go with something like this.
Mike
Old May 23, 2003 | 05:39 AM
Mystery Machine's Avatar
Mystery Machine
I love my ZZ4 motor. It runs great and was very little hassle dropping it in. It sounds excellent too. It's all a matter of preference...old tech, new tech, whatever. For ~$3K I don't think you can beat it! :thumbs:
Old May 23, 2003 | 06:56 AM
1969Vette383's Avatar
1969Vette383
I too am looking for a new motor but I've come to the conclusion that I really have to pull out some kind of bank loan. I figure that while the car will be down for awhile, I've got this pretty looking basket of part numbers sitting in my virtual shopping cart at one of our supported vendors. Those parts eclipse $1100 quite easily and I may as well buy all those at the same time. While I'm repairing/replacing the motor, I've always wanted a 6 speed in my car ... You guys saw where this was going after the first sentence.
So my "fix it" list and a T56 installed in my C3 :thumbs: Cool! But I still haven't tackled my powerplant issue. I've looked all over for GM crate motors too but found something I really want to do and it's almost in my price range. I saw what 70LS1 did and I knew I had to also. I want an LS1 in my car so badly! MMMMM *salivates* An uncorked, unsmogged LS1 in an older car :cool: Please guys, I do take donations :lol: The thing is, I could buy one even though I was told by my parents to drop the loan price by a few thousand, I just wouldn't have any money left over to pay a shop for the work needed. Yes my friends and I could do all the work ourselves, between the 6 of us we have the knowledge. The problem is getting all 6 of us together one place at a time. My car would be down from now until the end of this year; uhhhh no thanks, I want to drive it, not look at it.
I found a very low mileage (under 10k) 2001 T56 & LS1 combo with everything needed for less than it would cost me to buy both pieces separate. The only downside is that I wouldn't get the warranty of the transmission I'm looking at (see thread here: http://forums.corvetteforum.com/zerothread?id=567537 ). Would any of you feel safe in buying a drivetrain combo that had so few miles? The motor is just barely getting broken in by then and I'd feel safe about the mileage but nobody ever really knows about prior owners. If I could get the guy to separate the two parts, I'd go for his low mileage motor, ask him to drop his asking price and buy the T56 with the warranty. I guess I could ask, anybody here want to go in for just a slightly used T56?
My only other option right now is to go for 2 out of 3. It would save me enough money that I could buy all the parts needed to freshen up my car, I'd have a 6 speed manual, but I would get an inexpensive crate motor called an LM1. GM PART # 10067353 It's a shade over a grand in cost from gmpartsdirect.com, would be cheap and reliable (Cheap / Fast / Reliable; pick any 2 outta 3) but it's not exactly what I want. Though it too would have a warranty, as would the T56 and a few parts in my "fix it" list, so that's not bad.
I'm kindof hung up on this warranty stuff right now because if I get into a loan to fix my car, I don't want to turn around in 3 weeks and have to replace a part I just bought. I may as well roll the thing down a cliff with me in it and call it good- start from scratch somewhere else.
Thanks for the assistance. What would you recommend if you had $5500 total in funding and $1300 of it was already spoken for? Some has to be saved for labor cost and another $1400 is pliable in that it could go toward a transmission or an engine-transmission combo.
-Geoffrey
Old May 23, 2003 | 08:49 AM
Sun King's Avatar
Sun King
Default Re: Crate Motors (1969Vette350)
I'm uncertain that an LS1 long block would still put out 345/345 without the fuel injection/computers :skep:
[Modified by WS6TA01, 8:57 AM 5/23/2003]
Old May 23, 2003 | 01:32 PM
tshort's Avatar
tshort
CI 7-8 Veteran
There are lots of other options. Many of us on the forum have been buying from AR racing and have been real pleased with the service, quality, price, and performance. I just received mine but haven't finished the install yet. For just over $3K I got an aluminum head 383 stroker that will be pushing over 450hp and 470ft-lbs of torque. Makes the ZZ4 look kinda wimpy.
And forget about warranties. GM's warranty is the best I saw and they still only warranty parts. So if you throw a rod, they'll replace the connecting rod but you'll still have to pay for the new block, piston, rings, head, and other parts that were destroyed and also pay for labor. The warranty is useless!
Also, ask Olivier (GrandSportC3) about his AR engine. He's been running the hell outa his, knocking on 11's door and all for under $3K.
Old May 23, 2003 | 02:23 PM
groovyjay's Avatar
groovyjay
Yes it might be able to make that kinda power w/o the FI and Electronic, BUT who makes LS1 intake manifolds that works with carburator?
My next project will be something like this (It's a small block 454!):
955-101011
MoTown 454 c.i., 600 HP - Complete Engine
TECHNICAL SPECIFICATIONS
Block: MoTown cast iron with 4-bolt mains
Bore: 4.250''
Stroke: 4.00''
Cylinder Heads: MoTown 220cc aluminum
Crankshaft: Scat 4130 forged steel
Pistons: JE 4.250'' forged aluminum flat-top (10:1 compression)
Connecting Rods: High performance H-Beam forged rods
Camshaft: Crane solid lifter profile with Speed Pro lifters
Intake Manifold: MoTown aluminum
Carburetor: Modified 1050 cfm Holley Dominator
Valves: Manley Severe Duty stainless steel (2.125'' x 1.600'')
Timing Chain: Manley True Roller
Lubrication: Speed-Pro oil pump and Milodon stamped steel pan
Rings & Bearings: Speed-Pro ring set and Clevite bearings
Ignition: HEI distributor, 8mm spark plug wire, Accel spark plugs
Valve Train: Aluminum roller rocker arms, Manley 4130 pushrods
Balance: Internally balanced, Hardcore CNC Balancer
Assembly Components: Fel-Pro, ARP and Manley
Accessories: MoTown aluminum valve covers, chrome timing cover, ATI balancer
Warranty: 2-years or 24,000 miles.
Old May 23, 2003 | 04:13 PM
1969Vette383
-Oh, I would definitely utilize the fuel injection & computers in my '69.
-Okay, so with the GM warranty being crap, now it comes down to the T56. Should I get the one from P.R.T. http://www.phoenixhardparts.com/ or go for the one already mated to the LS1?
To Crate Motors
Old May 23, 2003 | 05:10 PM
Ryan77's Avatar
Ryan77
I'm with TShort, call AR Racing :yesnod: . They quoted me a price of just over $4,000 for an aluminum headed 383 with forged pistons, full roller valvetrain, and a bigger cam than what they usually us in that motor. It's based on the 470hp/465ft/lbs 383 but my version will put out about 500hp/490ft/lbs according to Desktop Dyno :cheers:
Old May 23, 2003 | 05:34 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: Crate Motors (Ryan77)
:withstupid: AR all the way :thumbs:
Old May 23, 2003 | 08:23 PM
dath's Avatar
dath
:withstupid:
My AR 383 is costing me $3500 shipped... The specs are at:
http://corvette.ficker.net/engine_spec.php
Just noticed, the torque is probably a bit low... I only updated the HP, not torque... No big deal, those are just estimates anyhow.
-dath
[Modified by dath, 7:26 PM 5/23/2003]
