Weak Hazard Lights...
Old May 27, 2003 | 10:04 AM
still-learning's Avatar
still-learning
Default Weak Hazard Lights...
Folks,
Where is the blinker for the hazard lights? I currently have replaced the wiring harness and I thought I replaced all of the blinkers. I currently have nice strong turn signals but the hazards have just enough juice to blink the interior lamps but nothing on the outside lamps.
Any ideas?
Old May 27, 2003 | 06:10 PM
72GACRZR's Avatar
72GACRZR
Default Re: Weak Hazard Lights... (still-learning)
I don't know, but when I get home tonight, I will look up where my '72s is and let you know. :seeya
Old May 27, 2003 | 10:37 PM
Ben Taylor's Avatar
Ben Taylor
On my 81 it is located above the fuses undeneath the steering colum.
Old May 28, 2003 | 12:04 AM
72GACRZR's Avatar
72GACRZR
If I read this right, it is located on the fuse panel. I don't have my car here,
Old May 29, 2003 | 07:48 AM
still-learning
Default Re: Weak Hazard Lights... (72GACRZR)
I think in the older cars it was on the fuse panel. I noticed a thread discussing this earlier. I am pretty sure that it is not on the fuse panel on a '77 but I am not sure. Steering column is starting to make some sense though... Hmmm...
Tim M.
Old May 29, 2003 | 10:44 AM
Ki m Le's Avatar
Ki m Le
Since I have 4 different year cars, I don't remember exactly which year, but I know the turn signal relay are located either under the AC control console(68?) or behind the pass lower dash pad (69-7?)
The Flasher is on the fuse panel.
[Modified by Ki m Le, 10:48 AM 5/29/2003]
To Weak Hazard Lights...
