Need Info/75vette
Old Jun 5, 2003 | 10:11 AM
Live75's Avatar
Live75
Cruising
Default Need Info/75vette
I found a wire that is not connected in the engine compartment. I traced it back and found it goes to the amp guage. The problem is I don't know where it is suppose to be connected . Any help on this problem will be appreciated.
Old Jun 5, 2003 | 03:33 PM
77Dream's Avatar
77Dream
Default Re: Need Info/75vette (Live75)
Welcome to the forum :seeya
Does your meter currently work?
I could take a good guess but I don't want to give you wrong information. You should get a good wiring diagram for your year vette. I have one from ecklers that is a laminated poster, Its the best diagram I have, but I still have others just in case.
Old Jun 5, 2003 | 04:22 PM
Rockn-Roll's Avatar
Rockn-Roll
There are two 16 gauge wires running from the ammeter. One is BLK and the other is BLK/WHT.
The BLK wire runs to the firewall terminal block and exits on the engine compartment side as a 20 gauge ORN wire then spliced onto a 10 gauge BLK wire that Y's into the 10 gauge RED wire that ends at the starter.
The BLK/WHT wire runs to the firewall terminal block and exits on the engine compartment side as a 20 gauge ORN thermal wire that jumpers back into the firewall terminal block where a 16 gauge RED thermal wire exits and is spliced into a 10 gauge RED wire that Y's into a 10 gauge RED wire that connects to the BAT terminal on the alternator as well as the V terminal (the plastic two wire connector) of the alternator.
Hope this helps.
Old Jun 5, 2003 | 06:21 PM
77Dream's Avatar
77Dream
Default Re: Need Info/75vette (Rockn-Roll)
Hope this helps.
:lol: And you thought is was going to be hard. Good luck :thumbs: :jester
I was going to say that it either goes to the starter or alternator, but I gess there is a little more to it than that. :smash:
Old Jun 5, 2003 | 07:17 PM
Greg's Avatar
Greg
Just another Corvette guy
Default Re: Need Info/75vette (77Dream)
Hey John,
Welcome to the forum! What color is the wire and where is it located?
Greg
Old Jun 5, 2003 | 09:16 PM
Live75's Avatar
Live75
Cruising
Thanks to all for the info on the wiring problem on my 75 vette. With your help i think i will be able to fix it. I do have the wiring diagram but not very clear where the black wire terminated. Thanks i really appreciate the help
To Need Info/75vette
