Carb Tuning????
Thanks guys
Smokin
I think the point of the accelerator pump is to provide a squirt of fuel to compensate for the sudden increase of airflow when the flaps open (primary and secondary in some cars) as you mash the throttle. The Qjet won't open the secondary airvalve until the engine creates enough airflow which in turn lifts the secondary metering rods up, providing more secondary metering area. At least I think that's what I derived from Lar's paper. If you haven't yet, check it out. It sure helped with my Qjet. I was getting a bog (secondary air valve spring had NO tension on it), poor throttle response ( jetted too lean) and intermittently opening secondaries (air horn tightened too much by Bubba and distorted. resulting in the flaps binding). I'm not sure how any of that would apply to your carb, but it might give you some ideas.
hopefully someone with Edelbrock experience with chine in.
[Modified by isosceles, 11:31 PM 6/24/2003]
Isosceles
I'm having some trouble figuring out which rods and jets to get. I'm trying to follow the charts, could you explain which is a 10%change.
If your carb is the Edelbrock version of the Carter AFB, the tuning tips I cover in the FAQ section do not apply - they apply to Q-Jet tuning only. The AFB is a completely different animal...
smokin
[Modified by Smokin80, 2:47 PM 6/25/2003]
Here's what I did, following Lars' paper:
Determined the need for rejetting by disconnecting the accelerator pump, flicking the throttle and almost seeing the car stall. Also, covering the airhorn at idle with my hand actually increased the idle speed, as covered in Tech tip 3 of that paper.
1. Made sure float level was correctly set. That's the first step covered in the "procedure'section of Lars' "How to tune a Q-jet (basic)" paper.
2. Took carb apart following tech procedure #1 off paper
3. determined that I had .071 primary jets and ..40 rods.
4. go to the chart labeled "figure 2" and look up your WOT metering area based on your jet size, but use the .026 rod to determine this. Remember that all rods are .026 at the WOT metering area. So for my .071 jets it is .00342826
5. Next, you'll need to consult another file on the FAQ labeled 'jet change chart', and Excel spreadsheet. In the second column there are a bunch of metering area numbers. Find the one closest to yours at WOT. Mine was .0034286, so mine matched up best on row 50.
6.Then scroll across until you get to the green shaded area on that same row, stopping at the column with the number closest to 10.000, but not over it.
7. Scroll up to the top of that column and write down the metering area. That number for me was 0.003739281. This is the my new WOT metering area I will try to get with my new jet/rod combo.
8. Go back to the chart labeled "figure 2" in the Tuning paper and look at the WOT metering areas for all the different sized jets. Remember to only look at the areas with the .026 rods. The jets I selected were .074 because with the .026 rod tip (remember all the rod tips are this diameter) the metering area is .00376991. From the spread sheet, I was shooting for .003739281 and this is as close as I can get (pretty close!)
9. Now you need to figure out which rods to use so that your cruise/idle metering area doesn't change. If you use the same rods you have now, and you increase the size of your jets, those same skinny rods might give too much metering area at cruise. Go back to the 'figure 2' chart and look at your cruise metering area for your old jet/rod combo. For my 71/40 set up, it was .00270256. This time you will use the actual rod size you have in that table, not the .026. The part of the rod that affects cruise metering area is .040 in diameter. (again, the tip is .026, that's the part that affects WOT).
10. So now, you need to go to the "figure 2" table and look in the section with your new jet size and pick out the rod that will give you close to the same metering area. I needed .074 jets to increase my WOT area by 10%. I need rods to give a cruise metering are of close to .00270256. Looking down the list I see that .045 rods will give me the closest to that at .0271041.
If you still have issues with the cruise/idle metering area, follow the instructions in the paper to test that. Lars will have you lock out the secondaries and make some test runs. An easy way to figure out rod change sizes is to multiply your metering area by 1.1 for leaner (thicker rods mean less metering area) or by .9 for richer ( skinnier rods mean more metering area).
I hope my example helped. It worked for me. I am still messing with the cruise area a little. I ended up going with my new jets and back to my old rods, but I think that makes my cruise a little rich. I still need to test that.
Follow the rest of Lar's procedures in the paper. That guys KNOWS Qjets!
:yesnod:
