Gas mileage with BB
Old Jun 24, 2003 | 10:48 PM
467-Ratman's Avatar
467-Ratman
Default Gas mileage with BB
I know that I should not be complaining about MPG with a BB, but around town I can watch the gas gauge drop like a rock. I am getting about 5 to 7mpg. My idle seems good, although a little wet sounding and WOT is fantastic. Should I mess with the idle screws to lean it out some. On my 850DP I am using 78 jets up front and 82 in back, and 6.5 power valves. Like I said I should not be upset about the gas but what is everyone else getting in there BB?
Old Jun 24, 2003 | 10:51 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: Gas mileage with BB (467-Ratman)
I got 13 mpg on the hwy with my old 750 dp. I am not even gonna guess with the 850 till I get it tuned. Its running so rich right now my exhaust detonates like a potato shooter after some "spirited" acceleration. :yesnod: :lol: :auto:
By the way, rear gears believed to be 3:08's
[Modified by LAvetteman, 9:53 PM 6/24/2003]
Old Jun 24, 2003 | 11:04 PM
zwede's Avatar
zwede
I'm getting 11-12 mpg city, but I got EFI. I think with a carb you should still see 9-10.
Old Jun 24, 2003 | 11:08 PM
Marks69BB's Avatar
Marks69BB
~10 around town and 13-14 mpg on the highway if I keep my foot out of it. Hwy mpg should improve slightly with the new Tremec but city mpg will suffer! :D
[Modified by Marks69BB, 10:10 PM 6/24/2003]
Old Jun 24, 2003 | 11:13 PM
ZL1powr's Avatar
ZL1powr
I get about 9 or 10 MPG around town and 13 to 15 on the highway. I have 76 jets on the primary side and 84's on the secondary side of an 850 DP with 6.5 power valve. The last dyno run I did with an air/fuel gage showed that I am still on the rich side at wide open throttle with numbers runnig in the 12.1 to 12.3 range. With normal driving my plugs are a nice tan color so I think my primaries are about right. Have you checked your plugs? If they are black you can probably lean out the primary side and help your milage.
Old Jun 25, 2003 | 10:55 AM
Bob Turner's Avatar
Bob Turner
467 Ratman,
I am planning on driving my '74 from Phoenix to the Cold Coast (San Diego) this summer and hope to get some mileage numbers.. I am figuring around 17 freeway with the overdrive.... We'll see....
Bob :cheers:
[Modified by Bob Turner, 7:56 AM 6/25/2003]
Old Jun 25, 2003 | 10:56 AM
BB wowbagger's Avatar
BB wowbagger
Default Re: Gas mileage with BB (Bob Turner)
Its not the MPG that counts,its the SPM (Smiles Per Miles) :cool: :cheers:
Old Jun 25, 2003 | 11:11 AM
Glutamine83's Avatar
Glutamine83
Default Re: Gas mileage with BB (BB wowbagger)
MPG is irrelevent, you drive a CORVETTE!!! :cheers:
Old Jun 25, 2003 | 02:09 PM
bigvette1's Avatar
bigvette1
Default Re: Gas mileage with BB (Glutamine83)
BB's and MPG's are really opposite terms. I have a 73 454 and running good 8 in town and 12 on the road is good.
Old Jun 25, 2003 | 02:29 PM
Fevre's Avatar
Fevre
Ratman
You running your vac adv?
Old Jun 25, 2003 | 09:10 PM
73 LS-4's Avatar
73 LS-4
Default Re: Gas mileage with BB (bigvette1)
The best I ever got was 13.5mpg being very nice to it, normally about 10mpg when mixed driving normally.
:cheers:
Pat Kunz
467-Ratman's Avatar
467-Ratman
Default Re: Gas mileage with BB (Fevre)
No vacuum advance, my engine guy said he does not like it. I am sure that would most likely help the mileage. I have told people that I dont get MPG its called smiles per gallon! Whatch out Dinos here I come....
Old Jun 25, 2003 | 09:17 PM
norvalwilhelm's Avatar
norvalwilhelm
I get an honest 12 mpg around town. I run 2 850 double pumpers with 80 jets all around and power valves. I lean out the idle alot, drill the throttle plates, all 8 of them to get the transfer slots closed. I am running leaner then 15-1 and my plugs look white. I hope for around 15 mpg on the highway but so far have not gone very far. Went 40 miles this morning in 93 degree heat and the vet never warmed up past 190 and the gas gage hardly moved.
To Gas mileage with BB
