73 BB Starter Wiring
My starter has the large lug on top of the solenoid and two terminals marker "R" and "S"
I have a wiring harness that has no colors in the wires, they are all individualy wrapped in absestos. Here are the terminals that I have.
+12 cable from the battery - this should go to the large terminal on the solenoid?
Frame ground cable - I assume ground to a starter rear support bolt that goes into the block.
A large ring terminal in the harness that is the size of the large terminal on the solenoid. This seems to go only on the large starter lug with the battery cable.
A black ground wire that is about 12 gauge. Assume you ground on the starter? Any place special?
A small lug with a straight spade connector on it.
A small wire with a lug bent at 90 degrees.
I would sure appreciate someone telling me which terminal to connect where. The wiring diagrams are confusing and referencing colors does no good as the the wires are wraped in absestos.
Thanks.
:banghead:
[Modified by bigvette1, 4:37 PM 7/1/2003]
