New bearings for 81 diff
Old Oct 29, 2003 | 05:08 AM
C3 - 81's Avatar
C3 - 81
Default New bearings for 81 diff
How hard is it to put new bearings into 81 diff. Do i need any speical tools. Diff already removed from car. Are these all the parts i need. Or am i better off giving to to somebody who knows whar they are doing.
Many Thanks in advance.
Mick.
Old Oct 29, 2003 | 07:07 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: New bearings for 81 diff (C3 - 81)
you're better off having it done, the bearings need to be shimmed so the contact with the race is set up correctly, the aluminium casings shrink and expand with temperature and to set it up properly you'll have the spread the case a bit.
Old Oct 29, 2003 | 08:08 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Default Re: New bearings for 81 diff (Twin_Turbo)
:iagree: 80-82 rear ends are not fun to do either. PITA
Old Oct 29, 2003 | 09:51 AM
ram82fire's Avatar
ram82fire
Default Re: New bearings for 81 diff (Van Steel)
what he said :iagree:
gman
Old Oct 29, 2003 | 09:58 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: New bearings for 81 diff (ram82fire)
Hey G :seeya
Old Oct 29, 2003 | 10:50 AM
Eds82's Avatar
Eds82
I just had my 82 diff rebuilt with all new seals, bearings and gears and I took it to a qualified mechanic to have it done. Everybody tells me they are a real PITA to do. Even the mechanic said so.
That kit looks like the one I purchased from Bairs. If it is then it is incomplete. You will be missing 2 inner bearings.
Hope this helps.
Ed
Hey Turbo, have you heard from Ken about when the Vault will be up and running again?
Old Oct 29, 2003 | 10:55 AM
Eds82's Avatar
Eds82
Oh yea, also those ring gear bolts in the kit are not as beefy as the stock ones. Best to get the same type bolts or better that came from the factory.
Ed
Old Oct 29, 2003 | 11:27 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: New bearings for 81 diff (Eds82)
Hey Ed, last I heard from him the dude that was supposed to install the cable modem didn't pack a raincoat and it was raining so he left. Haven't heard anything since.
Old Oct 29, 2003 | 04:48 PM
Eds82's Avatar
Eds82
Thanks for the update Turbo. Hope he gets it up again soon. I finallly got back from Singapore Sunday.
Ed
Old Oct 30, 2003 | 04:10 AM
C3 - 81's Avatar
C3 - 81
Thanks for the info guys. I will get it done by others and will chase up the bolts and other parts.
Old Oct 30, 2003 | 05:42 AM
MIKER's Avatar
MIKER
I changed the gear ratio in my DANA 44 rear end along with replacing the bearings. Here is a link to my post about it.
I have completed setup of the 3.73:1 gears in my DANA 44 http://forums.corvetteforum.com/zerothread?id=193247
You can save a LOT of money by doing it yourself if you have the right tools for the job.
To New bearings for 81 diff
