New Flex a Lite fan
Old Nov 6, 2003 | 11:58 PM
blunsford's Avatar
blunsford
Default New Flex a Lite fan
This fan appears superior to me. Twice the flow, variable speed, designed for a Corvette, Includes AC relay.
All for the same price as the Spal's. $369.00 at Jegs
I like the flaps that open up at highway speed to allow max air flow without the fans on.
What do you think?
http://www.flex-a-lite.com/auto/html...-electric.html
[Modified by blunsford, 5:04 AM 11/7/2003]
Old Nov 7, 2003 | 12:21 AM
Spook's Avatar
Spook
Default Re: New Flex a Lite fan (blunsford)
Im in love with my flex-a-lite dual setup and thats all that she wrote!
Old Nov 7, 2003 | 12:25 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Saw that too - too bad the price is so damn high.
I don't see any C3's over 76 listed.
Mounting Surface Required - 17½" x 27½" x 4"
The low profile #210's fit the core in my 1980 perfectly, and those were 15 1/2" x 26 1/4" x 2 5/8".
That extra 1 1/4 width and 1 1/2 inch in thickness may be a problem.
Anyone know the dimensions of the Spal's ?
Old Nov 7, 2003 | 01:28 PM
Brettmc's Avatar
Brettmc
Spal's, I believe, are the only fans rated through resistance, like you would find them in real life, on a radiator.
Brett :thumbs:
Old Nov 7, 2003 | 02:43 PM
gkull's Avatar
gkull
Default Re: New Flex a Lite fan (Brettmc)
This is th Spal fans I have and they are not enough cooling for my application.:( I'm having a race shop fabricate an aluminum mount shroud so it pulls through the whole radiator. I presently have to have them both running full blast on a 14.1 volt system and they don't keep up in hot weather. Which also required me to install a 106 amp alternator
#30100846 Dual 11 Inch Spal Fan - (Pull) 16.26" 23.46" 4.25" 2780 CFM
For medium powered cars like 500 hp big blocks they might be OK!
To New Flex a Lite fan
