AutoZone P/S pump?
Old Nov 7, 2003 | 10:59 AM
Augie 79's Avatar
Augie 79
Default AutoZone P/S pump?
I have 1 power steering leak and it is at the pump around the new pressure hose. I don't feel like tackling a pump re-build and was thinking of stopping by AutoZone today after work and buying one of their re-build pumps. I just checked and they have them for $48 with "Atsco" reservoir or $45 with out the reservoir. Wonder which one I need? Anybody have any experience with their power steering pumps? Thanks
[Modified by Augie 79, 10:05 AM 11/7/2003]
Old Nov 7, 2003 | 11:05 AM
Shark Racer's Avatar
Shark Racer
Default Re: AutoZone P/S pump? (Augie 79)
Don't have experience, but make sure they have a good return policy.
-Steve
Old Nov 7, 2003 | 11:08 AM
Tom454's Avatar
Tom454
If it's the pressure hose connection, then a rebuilt pump will not cure it.
You just need to re-tighten the fitting.
To replace the pump, you will have to do the same task.
If the hose fitting is bad, you will be back to square one even with a new pump.
Old Nov 7, 2003 | 11:17 AM
zwede's Avatar
zwede
I got a rebuilt pump from NAPA. First one leaked so got a free replacement. The second one has been fine for many years now.
Old Nov 7, 2003 | 11:20 AM
Augie 79's Avatar
Augie 79
Default Re: AutoZone P/S pump? (Tom454)
Good point Tom! Before installing Zips rebuild kit this was the one area I didn't have a leak. I may have loosened it when I removed the old line. I'll put a wrench on it tonight. Thanks
Old Nov 7, 2003 | 01:37 PM
79 Midnight Blue L82's Avatar
I have had my AutoZone rebuilt PS pump with reservoir on for about 2 years now and I have not had any trouble with it at all. No leaks or squeals at all.
If you have not done this before you will need a special puller to get the pulley off the old pump and back on the new pump. I borrowed one from a mechanic buddy.
Old Nov 7, 2003 | 01:44 PM
Jasonty's Avatar
Jasonty
Default Re: AutoZone P/S pump? (79 Midnight Blue L82)
Whatever you do, don't buy a new pump from Pep Boys... I worked there as a mechanic for about 5 months, and I've never gotten so many defective parts in my life. :eek:
Old Nov 7, 2003 | 02:02 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: AutoZone P/S pump? (Jasonty)
Yeah - the few parts I have bought from them have sucked. I only buy small stuff, made by other compaines, from their store.
For parts I go to NAPA.
Old Nov 7, 2003 | 04:49 PM
Jim Shea's Avatar
Jim Shea
In 1980 the pump connection on all GM vehicles changed from a 45 degree flare fitting to a metric o-ring connection. Make sure that you aren't trying to install a 45 degree flare hose (your original hose) into a metric pump fitting. If you have a 45 degree flare hose, you should look into the pump discharge fitting and see a brass 45 degree seat inside the fitting. No brass seat? You most likely have a 1980 or newer metric pump.
Old Nov 7, 2003 | 04:59 PM
Augie 79's Avatar
Augie 79
Default Re: AutoZone P/S pump? (Jim Shea)
Thanks everybody for the info and ideas. Jim Shea I was reading the many papers you have on the subject at corvette FAQ, I'm impressed. Jim if you told me to run out to the parking lot and spit in the pump.......I'd do it. Thank you for the personnal response, I'm hopeing it's just a lose fitting on the back of the pump common to the pressure hose. It's not a metric fitting by the way. Thanks guys!
To AutoZone P/S pump?
