Please recommend a piston ring?
Old Nov 9, 2003 | 11:13 AM
ImBatman's Avatar
ImBatman
Default Please recommend a piston ring?
Ok this may be a really stupid question but I can't seem to find a piston ring set for my application. Here is what my question is. I am building a 454 street motor. I have already ordered a set of speed pro hypereuetic pistons that will yeild 10.5:1 with my heads. Could you please recommend a piston ring set ? My pistons are + .030 giving me a bore size of 4.280. This is mainly a weekend street car. Would like a good molly style that want blow my budget.
When I look at the ring sets in the catalogs I see the more expensive rings referring to my bore size which is 4.280. But when I look at the rings they don't list my bore size and that is confusing me. Example, Speed Pro file fit molly ring is listed for 4.280 and costs $85 a set. where as Childs and Albert dura molly rings list a 4.155 and then jumps to a 4.310 :confused: I would think that a .030 454 would be very common.
Old Nov 9, 2003 | 02:27 PM
PRESSURERAT's Avatar
PRESSURERAT
Default Re: Please recommend a piston ring? (BlackRat)
TTT!!!!! At great risk of highjacking this thread, I want to know why plain ol' cast rings won't work just as well as moly ones. :flag
Old Nov 9, 2003 | 03:29 PM
ImBatman's Avatar
ImBatman
Default Re: Please recommend a piston ring? (PRESSURERAT)
Hey this is my thread!!!! :mad :D Just kidding good question I would like to hear some answers on this as well.
Wade
Old Nov 9, 2003 | 09:48 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I have always had fantastic luck with Speed Pro rings. They just always flat work. Some folks have success with the zero gap style, but I think they work best in specific applications. Many folks have issues with them. Not worth the trouble to me to experiment.
I don't see NASCAR, OEM or professional drag racers using them, so I'll just stay with what works.
Plain cast ironn sets are cheaper and work fine in a old cylinder bore that isn't perfect. If you're going to the trouble of boring and new pistons.don't scrimp on the rings.
Pay close attention to ring gaps on the Hypereutectic pistons. Often they require wider gaps to keep from butting with the higher piton crown temps.
The rings you need are very common. Just call Jegs or Summit. They just don't have everything listed in catalogs.
JIM
[Modified by 427Hotrod, 8:50 PM 11/9/2003]
Old Nov 9, 2003 | 10:19 PM
ImBatman's Avatar
ImBatman
Default Re: Please recommend a piston ring? (427Hotrod)
Thanks for the info Jim. Do you recommend the file fits or find a set that are pre gapped? If I go with the file fit do I have to buy a special tool to cut them?
Wade :thumbs:
To Please recommend a piston ring?
