383 for a 69'
Old Nov 11, 2003 | 08:36 PM
1969stingray1969's Avatar
1969stingray1969
Default 383 for a 69'
What do u think about supercharging a built 383 boostin bout 15 pounds. I'm thinking it should run 10's easily with around 800-1000 horsepower at the tires what do u guys think? :thumbs: :auto: :steering:
Old Nov 11, 2003 | 09:29 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Default Re: 383 for a 69' (1969stingray1969)
Works in my buddy's 383!! (Road Runner) :D
Dep
Old Nov 11, 2003 | 09:33 PM
1969stingray1969
Default Re: 383 for a 69' (Dep)
is that what he runs and about the horsepower? and im thinkin i no a guy and i think and wish it will cost around 10g's :smash: :crazy: :D :thumbs: :chevy
[Modified by 1969stingray1969, 2:35 AM 11/12/2003]
Old Nov 11, 2003 | 09:35 PM
gdh's Avatar
gdh
what compression are you running now?
Old Nov 11, 2003 | 09:37 PM
1969stingray1969
is that what he runs and about the horsepower? :smash: :crazy:
Old Nov 11, 2003 | 09:39 PM
1969stingray1969
Default Re: 383 for a 69' (gdh)
i dont have it done yet but im thinkin ill start getting the engine built by march and hopefully this guy i no will be able to supercharge 2 :D
Old Nov 11, 2003 | 10:04 PM
Gordonm's Avatar
Gordonm
You had better beef the rest of the drive train. You will spit the stock rear out if you run any kind of tire. Slicks will require some major money in the rear.
Old Nov 11, 2003 | 10:17 PM
1969stingray1969
Default Re: 383 for a 69' (Gordonm)
ya I forgot about the tires but i got P295/50 R15 on the back and im going to see about the transmission
[Modified by 1969stingray1969, 3:17 AM 11/12/2003]
Old Nov 11, 2003 | 10:37 PM
1969stingray1969
what do you think ill b running if i get all the engine, supercharger around 15lbs., and transmission, and prolly rear axle :auto:
Old Nov 11, 2003 | 11:19 PM
ScubaJKD's Avatar
ScubaJKD
Dont know what you will be running in the quarter but you will certainly be running some red lights unless you get some stoppie for that beast.
Moss
:cheers:
Old Nov 12, 2003 | 04:54 PM
1969stingray1969
Default Re: 383 for a 69' (ScubaJKD)
well i got 4 wheel disk all around i think that should b pretty good
:iagree:
how do u post pics on here and ill show u my car
:auto:
[Modified by 1969stingray1969, 9:57 PM 11/12/2003]
Old Nov 12, 2003 | 05:09 PM
dath's Avatar
dath
Your transmission is going to be only one small worry. The stock IRS isn't going to take that kind of power without some serious mods. Check out what Van Steel has to offer (they're a supporting vendor) and see what they say about that kind of power with slicks at the strip... In my opinion you should be able to run 10's with less than 700HP, but I'm sure if you ask around you can find someone who's really doing it. I'm hoping to be in the 11s with a ~450HP 383 and a ~150 shot of nitrous oxide... Stock IRS won't take that either, so I probably won't run on the track for some time after I've got everything setup...
Old Nov 12, 2003 | 05:13 PM
1969stingray1969
Default Re: 383 for a 69' (dath)
are you buying a crate engine or are you building it or having someone build it. If your building it you could spray more than that though :steering:
Old Nov 13, 2003 | 05:10 PM
dath's Avatar
dath
AR is building it for me... I probably could spray more, but to start with, I'm really only going for ~100HP... I don't have the time/money to mod my IRS a whole bunch and don't really want to leave parts on the track since I don't have a trailer to get my car to and from the track on :rolleyes: If you want to check out the specs for my engine build, you can look at:
http://corvette.ficker.net/engine_spec.php
What's not there is the comp ratio (10:1), and the pistons are probe forged... External balance, yada, yada... I'll probably step up to a 73 nitrous and 82 Fuel (150+HP) setup at some point, but I don't have a fancy ignition that will let me retard the timing, so I'll have to tune it for power when I'm planning on making it, then change it back... A bit annoying. Enough excuses? One more... This is also my first time ever playing with a "performance" engine setup, so I'm relatively new and don't want to make any stupid mistakes.
:cheers:
Old Nov 13, 2003 | 05:24 PM
Corey_68's Avatar
Corey_68
Well, I'll be the first to tell you it's not as easy throwing a hot motor in a stock car and run"10"s". It takes a lot more than Horsepower to run low numbers at the strip. I'd imagine a 1,000hp boosted small-block is capable, but longevity comes into play as well. Getting a small block 383 to reliable 1,000hp under $10K may be tight, you would need quality parts not counting a deadicated fuel system.
You would need:
suspesnsion upgrade
Rear End
gears
tranny
halfshafts
drive shafts
radiator
slicks
If you can get the 1,000hp and it holds you will need to install at least a 6pt. cage in the car to run 10's more than once (NHRA rules)
Best of luck
:cheers:
[Modified by Corey 68, 4:29 PM 11/13/2003]
[Modified by Corey 68, 8:40 PM 11/13/2003]
Old Nov 13, 2003 | 05:49 PM
1969stingray1969
Default Re: 383 for a 69' (Corey 68)
ya my brothers friend will build it for me and i can put the roll cage in and my other brothers friend can rebuild the transmission so yay :D :hurray: :flag
Old Nov 13, 2003 | 06:15 PM
Corey_68's Avatar
Corey_68
Now all you have to do is get your Driver's Liscense. :D
To 383 for a 69'
Old Nov 13, 2003 | 08:01 PM
1969stingray1969
i already have my motorcycles lisence so all i have to do is when i turn 16 is go in and take my driving test woohoo 9 months :flag
Old Nov 13, 2003 | 08:39 PM
dath's Avatar
dath
I'm telling you, if you plan to stick with the IRS (or even change it), you're in for some serious spending. It'll cost you several thousand to handle the kind of power you're talking about. Corey is right, it's not easy to just slap this all together and run 10's (at least not for the budget minded). The rear setup done properly will easily cost you the price of a built transmission plus some... Only reason I know is because I'd like to work on my rear end after my engine swap:D
EDIT: Oh yeah, if you hit 1000HP, I think you'll be leaving 10s long behind if you can hook up and don't break parts. With that kind of power, you will find the weak links :D
[Modified by dath, 7:41 PM 11/13/2003]
Old Nov 13, 2003 | 08:50 PM
Ryan77's Avatar
Ryan77
[QUOTE]
You would need:
suspesnsion upgrade
Red End
gears
tranny
halfshafts
drive shafts
radiator
slicks
Best of luck
:cheers:
[QUOTE]
:iagree: I'll be running a 525hp 383 with probably a 100 or 150 nitrous shot. To handle this power I'll be going to a complete Tom's Diff's rearend setup ($5k+), a ROD 6 speed ($3k) and complete Be Cool cooling system ($1k). So those parts alone not including the motor or nitrous will run me almost $10k. You always have to remember the old saying, "speed costs money, how fast do you want to go?" :D
