interior light 77
Old Nov 13, 2003 | 08:47 PM
ddaveyboy@home.com's Avatar
ddaveyboy@home.com
Default interior light 77
Hi guy's
I currently own a mid year roadster & we just purchased a 77 coupe for my wife. I have never encountered this problem before. When I open the door ( drivers or passengers) the interior light is delayed coming on for about 10 seconds. This seems odd. I know they will delay shutting off, but I hav'nt run across this before
Thoughts?
Dave :confused:
Old Nov 13, 2003 | 08:57 PM
Bobchad's Avatar
Bobchad
Default Re: interior light 77 (ddaveyboy@home.com)
Relay could be going bad. Mind went bad and would delay the turning off further and further until it quit tunring off. A real PITA to change. Requires taking off the upper dash pad.
Bad switches are another possibility but that seems unlikely that both would go out in the same way at the same time.
[Modified by Bobchad, 8:58 PM 11/13/2003]
Old Nov 13, 2003 | 10:23 PM
ddaveyboy@home.com
Default Re: interior light 77 (Bobchad)
Ya I kinda figured it would be a relay of some sort. I have to change the heater core as it is leaking. Can I access the realay when I have the centre gauge cluster out?
Thanks again
Dave
Old Nov 13, 2003 | 11:13 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
No. But pulling the upper dash pad isn't that bad.
First, pull off the interior, plastic t-bar header cover. Then, pull off the left and right interior A pillar covers . Then, remove the screws at the lip of the dash that attach the upper cover to the left and right side dash covers (basically these screws run all across the top of the front dash).
Now comes the tricky part. You can do this by yourself, but it helps to have a friend's help. Or two. Push up on the middle of the upper dash pad (where the gauge cluster attaches) while pushing down on the outer edges. Then, simultaneously lift up and out. Basically, you're trying to make the outer edges of the dash pad clear the A-pillars. Putting it back is the reverse of taking it out. Not too bad at all.
Just be gentle, as the plastic frame of the upper dash pad can be brittle. If you have a mishap, some 2 part epoxy will do wonders to piece it back together. Heck, while you have it out, I suggest repainting it with the proper vinyl dye. Also, replacing the front speakers and instrument cluster bulbs is not a bad idea.
Okay, so now the upper dash pad is off. On the driver's side, you'll see a silver cannister. This is the interior light relay. Pull it out and put in the new one.
Welcome to the '77 club. My 77 was my first Vette, and I love it.
:cheers:
[Modified by joeveto, 10:15 PM 11/13/2003]
Old Nov 14, 2003 | 01:07 AM
ddaveyboy@home.com
Default Re: interior light 77 (joeveto)
Great tips
Dave
Old Nov 14, 2003 | 06:03 AM
Bobchad's Avatar
Bobchad
One step is missing here and probably not mentioned because of your indicating you were going to replace the heater core and the assumption that it would be out already. You have to remove the lower right dash pad as there is one screw underneath the dash pad that holds the dash down.
[Modified by Bobchad, 6:04 AM 11/14/2003]
To interior light 77
