Coolant
Old Nov 29, 2003 | 09:54 AM
Yeller81USNRet's Avatar
Yeller81USNRet
Default Coolant
Is it Advisable to mix Prestone Anti Freeze with the Dex-Cool coolant.
This is in my 98 Olds. Intrique and it still has the original coolant in it .
Do you guys think the coolant will be OK for a West Virginia winter . It was like 28 out this morning and I know it will get a lot colder ..
Thanks in advance..
:steering:
Old Nov 29, 2003 | 11:23 AM
Jack71's Avatar
Jack71
Default Re: Coolant (Yeller81USNRet)
Not supposed to mix them without a complete system flush or the two create a "gel" that causes havoc on your system. Do a search in the Archives on "dexcool"...
Old Nov 29, 2003 | 11:26 AM
Ben Taylor's Avatar
Ben Taylor
If you mix the green and orange coolants together you will end up with a brown pile of sludge in your radiator and engine. Prestone makes a Dex-Cool approved coolant that usually costs about $8 a bottle. Dex-Cool is a better coolant than the old greeen stuff, it's supposed to last twice as long, and cause far less corrosion, especially on aluminum radiators.
Old Nov 29, 2003 | 01:50 PM
zwede's Avatar
zwede
Depends on which "prestone anti-freeze" you are talking about. If its the bottle that says "dex-cool approved" and is orange than yes, you can mix it with GM dex-cool. If the prestone stuff is green you'll end up with a witches brew that may well plug up your entire cooling system.
Old Nov 29, 2003 | 10:07 PM
comp's Avatar
comp
Default Re: Coolant (zwede)
mixing the two different anti-frez. can cause a chemical reaction, my daughter
had hubby top of coolant with (green) on top of long life (pink) took about a
year and the steel coolant line under intank from water pump to back of block
let go (rusted) 4.6 2v in a 96 couger. it got paper thin before it let go, got info
from a tech. a a dealer ship
Old Nov 29, 2003 | 11:14 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: Coolant (comp)
:iagree: Stick with what the system had in it before.
Old Nov 30, 2003 | 04:28 AM
Yeller81USNRet
Default Re: Coolant (LAvetteman)
Thanks guys. Glad I asked before I dumped it in.
You all SAVED me a big hassle.
Thanks Again.
:steering:
To Coolant
