Intake - matching...
Old Dec 4, 2003 | 08:58 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Intake - matching...
Yesterday - I started to match my Victor Jr. intake to the Felpro 1205 gasket...
It really isn't too difficult... I used a (cone shaped) grinding stone in my drill to take off most of the material and a Dremel tool smooth out the surface and work the edges better. I finished one runner and most of a second runner... So far - I spend around 1 hours.. so it'll be around 4 - 5 hours of work to finish matching the intake to the gasket!!
[Modified by GrandSportC3, 9:26 AM 12/4/2003]
Old Dec 4, 2003 | 09:07 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Intake - matching... (GrandSportC3)
I wonder what a before and after dyno would be worth on this type of matching. I did no matching on mine and the guys at work gave me a hard time for not. Any ideas.
Old Dec 4, 2003 | 09:26 AM
GrandSportC3
Default Re: Intake - matching... (Eddie 70)
I guess that it's only worth very little.. but I'm sure that it could be 2 - 3 HP or so... but I have no idea...
Old Dec 4, 2003 | 09:38 AM
comp's Avatar
comp
blend in the match about 1-1.5 in. into port , it will smooth the transition
Old Dec 4, 2003 | 09:41 AM
GrandSportC3
Default Re: Intake - matching... (comp)
That's what I did :yesnod: :yesnod:
Old Dec 4, 2003 | 09:59 AM
killervette666's Avatar
killervette666
Im planning om doing the same thing over winter except matching the heads to, i thought you had a buy a porting/matching kit...... thanks for the info, now i wont waste $30. :cheers: :smash:
Old Dec 4, 2003 | 10:03 AM
GrandSportC3
Default Re: Intake - matching... (killervette666)
I bought a grinding kit for my Dremel and a grinding stone (cone shape) for my drill.. I spent a total of $18 for everything...
Old Dec 4, 2003 | 10:15 AM
The Money Pit's Avatar
The Money Pit
I used the 1205 gasket when I did my RPM intake.I used a lift plate and bolted the intake to in,then upside down in the bench vise.Perfect working angle.No dremel tool,I filed mine by hand with a couple different size half round files.Managed to get two done a day,smoothing down the port an inch or so.
The AFR heads fit the 1205 gasket perfectly,and since they were brand new and I was still feeling the sticker shock,I left them alone.
When I installed the intake I used a thin coat of black RTV on the head side of the gasket,positioned the intake carefully and lightly torqued the bolts.The next day I removed the intake,checked the gasket alignment,then again a thin top coat of RTV and carefull placement of the intake.I think the port match can't get any better than that,and in over a year,not a leak to be had.
Did it make a bunch of power?Probobly not. :skep:
Old Dec 4, 2003 | 10:19 AM
gdh's Avatar
gdh
Glad to hear you are not wasting your time polishing after you finish porting.
Old Dec 4, 2003 | 10:23 AM
GrandSportC3
Default Re: Intake - matching... (gdh)
Absolutely! I don't think that polishing does anything... The only thing that I like polished is the outside of the intake :D and it's already polished...
To Intake - matching...
