Rear Spring Question
Old Dec 5, 2003 | 11:05 PM
VietNam_Vette's Avatar
VietNam_Vette
St. Jude Contributor
Default Rear Spring Question
I need help again. I've never seen a suspension like this until a month ago, and I'm lost. Is the rear spring supposed to be almost flat when the rear wheels are on the ground, or should there be some bow to it?
I'll try to attach a picture, if I can figure THAT out.
Old Dec 5, 2003 | 11:25 PM
johnnybrewmeister's Avatar
johnnybrewmeister
Default Re: Rear Spring Question (VietNam_Vette)
flat is bad, i.e. no spring left and time for a replacement. this is the time most people upgrade to the fibreglass mono-spring.
Old Dec 5, 2003 | 11:58 PM
Crash Dummy's Avatar
Crash Dummy
Default Re: Rear Spring Question (johnnybrewmeister)
It appears to be the stock leaf spring you have there Vietnam_Vette. It's bound to be near it's end. The 360lb rear mono-spring I just put on definitely has a bow to it and it definitely firmed up the rear end. There are some good vette suppliers on this site who will gladly make some recommendations as to what to use. I went with a VBP rear spring. And take the time for some good shocks on at the same time if you make the change. Bilsteins are not cheap, but probably some of the better alternative shocks.
Old Dec 6, 2003 | 12:54 AM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Default Re: Rear Spring Question (71-LS5)
Vietnam Vette, here's a picture of my spring before I started the composite spring replacement tonight. She was pretty flat on both sides. Check out my thread, I'm installing a TRW 355# composite spring (from Van Steel) on Saturday and will be posting assembly and hopefully, by the end of the day, performance thoughts.
Old Dec 6, 2003 | 06:32 AM
VietNam_Vette
Thanks for all the quick replies. Looks like it's time to start shopping for a spring.
Old Dec 6, 2003 | 02:03 PM
GTR1999's Avatar
GTR1999
VV- since you're new to vettes I suggest you check the archives to see which spring you may want. There's pro's and con's to both.
The repalcement steel springs are not exactly like the originals,which you can't get anymore. They cost less then the 'glass springs,are about 40 lbs heavier, don't look the same incase you're into NCRS type things, and don't usually fit without mod's. I have installed 3 repalcement steel springs and they all were too wide,but not the wider later model springs. I had to grind radius reliefs in them to bolt them up to the covers. They work ok,but I had to use 8" long bolts to level the rear of the car. I had to do this with both 7 & 9 leaf steel springs.The stock 6" bolts left the car about 2" high.
The 'glass springs break and heat seems to be one reason. I don't know if they have the mounting issues the steel do, but are easier to install. There are a lot of opinions on which one is best so I would read through the archives first before ordering.
Good luck,
Gary
Old Dec 6, 2003 | 06:38 PM
74 vert's Avatar
74 vert
Default Re: Rear Spring Question (gtr1999)
I'm installing a TRW Spring and I'm running into a problem. Check it out and please, please lend some ideas.
Old Dec 6, 2003 | 07:11 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Take a look here --- https://www.corvetteforum.com/techti...D=75&TopicID=3
To Rear Spring Question
