carb base gaskets, whats the right stackup?
Old Dec 6, 2003 | 08:31 PM
Surfer69's Avatar
Surfer69
Default carb base gaskets, whats the right stackup?
I have a thick (.2) cardboard, a thin cardboard and a thin steel type gasket all stacked together. Im just wondering if it matters what order they are in and can someone tell me why so many? THX
Old Dec 6, 2003 | 09:03 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: carb base gaskets, whats the right stackup? (Surfer69)
I only have one 50 cent cheapie, works fine, maybe the previous owner put a new one on every time he took the carb off :lol:
Old Dec 6, 2003 | 10:53 PM
AKRAY4PLAY's Avatar
AKRAY4PLAY
sounds like you have the remnants of a heat shield kit. the order is not important, except that every metal surface must touch a paper one. running several metal and fiber gaskets Brian
Old Dec 7, 2003 | 08:50 AM
comp's Avatar
comp
Default Re: carb base gaskets, whats the right stackup? (AKRAY4PLAY)
yep, he's got it. thats where the metal is getting a seal.(no vac. leak)
Old Dec 7, 2003 | 08:04 PM
PRNDL's Avatar
PRNDL
Default Re: carb base gaskets, whats the right stackup? (comp)
see if this helps:
http://forums.corvetteforum.com/zerothread?id=203910
Old Dec 8, 2003 | 09:50 AM
Surfer69's Avatar
Surfer69
Default Re: carb base gaskets, whats the right stackup? (MNJack)
That's it exactly MNjack, thanks! Of course Lars always has the answers. I wonder if he still has any packages left? :thumbs:
Forgot to mention I have stock Qjet setup.
[Modified by Surfer69, 8:54 AM 12/8/2003]
Old Dec 8, 2003 | 10:37 AM
lars's Avatar
lars
Surfer -
If you have the "smiley-faced" exhaust crossover forward of your primary throttle bores, you have to use the 3-piece gasket set, and installed sequence is of great importance. The high-temp composite gasket with the groove goes down forst, followed by the stainless steel heat shield, and then a 4-hole gasket with the "bulge" on the driver's side goes down last with the carb on top.
Yes, I still have kits available. E-mail me for info at:
V8FastCars@msn.com
Old Dec 8, 2003 | 12:06 PM
LemansBlue68's Avatar
LemansBlue68
Default Re: carb base gaskets, whats the right stackup? (lars)
Lars, If you've still got some kits hanging around, I'm interested. I just sent you an e-mail.
As always, THANKS!!!
Eric H.
To carb base gaskets, whats the right stackup?
