new side pipes!
Old Dec 13, 2003 | 09:12 PM
Chuck-75's Avatar
Chuck-75
Default Re: new side pipes! (SIGNGUY)
:conehead ok, I have to ask?, (because I purchased a set of Hooker Sidepipes ,simmiluar to what you described?, ) signman Pls tell me how I should go about installing ?, and cutting :U my expensesive side trim? :( , I very much love the new look that the sidepipes make... I also have a white 75 and have just been to afraid to tackel the cutting part of the instilation :cry . ...... very much kudos to yr new baby. ... :seeya save the wave.
Old Dec 13, 2003 | 09:27 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: new side pipes! (Chuck-75)
I agree these cars look best with sidepipes.
Old Dec 13, 2003 | 10:40 PM
Jasonty's Avatar
Jasonty
Default Re: new side pipes! (OHSIXX)
Do you have a JCW part number or link for those pipes? I've been looking for those, but couldn't find them on their website...
Old Dec 13, 2003 | 11:17 PM
VietNam_Vette's Avatar
VietNam_Vette
St. Jude Contributor
Default Re: new side pipes! (Jasonty)
"Do you have a JCW part number or link for those pipes? I've been looking for those, but couldn't find them on their website..."
Go to their website, http://www.jcwhitney.com , and search their site for "headers"...It returns five pages and they're on the last page.
Old Dec 14, 2003 | 01:20 AM
Nomad78SA's Avatar
Nomad78SA
Default Re: new side pipes! (VietNam_Vette)
Yep, Sidepipes are cool...
Neil in Tenn
Old Dec 14, 2003 | 03:08 AM
WESCH's Avatar
WESCH
Hi
I'm running the HOOKERs, no real cutting was required.
Very slight trimming at one side where the pipes pass under the fender, but would be easy to reglass.
The side pipe attachments pass underneath, no cutting.
Don't know about the JCW's.
I wonder if lowering the engine mounts a touch could be done to clear the pipes a bit more ?
OK, so the JCW are not fake, they actually fume out of the sidepipes. That's what counts.
Good luck. Gunther
:seeya :cheers:
Old Dec 14, 2003 | 03:16 AM
OkeeGuy's Avatar
OkeeGuy
heres the link... http://www.jcwhitney.com/webapp/wcs/...&storeId=10101
heres the part number...21ZX3927W
its the 3-1/2 inch X 2 inch X 63 inch
Chuck...as far as the triming goes...i know...
i hated cutting that trim piece too...
i dont know how to describe exactly how to go about cutting that piece other than to say "very carefully"...
i just held it up there...marked it...measured how far down and reluctantly started cutting...
i used a dremel with a cutting wheel and got really lucky and got it right the first time...
then i filed the edge that i cut to smooth it out...
mine were semi flat black so i dusted them with a freah coat before reinstalling them...
good luck!
and remember...its better to cut too little off instead of too much cause you can always take more off but you cant put it back! :D
[Modified by SIGNGUY, 3:27 AM 12/14/2003]
Old Dec 14, 2003 | 10:12 AM
Red73's Avatar
Red73
Here are the cutting instructions from my Hooker sidepipes.
Old Dec 14, 2003 | 10:18 AM
Paul L's Avatar
Paul L
I have followed your rebuild work with great interest. You have done a very fine job on that car. Congratulations!
Old Dec 14, 2003 | 10:45 AM
foundvettelifeisgood's Avatar
Looks great. I'm looking forward to seeing your high quality pics, especially of the work underneath.
:cheers:
Old Dec 14, 2003 | 10:59 AM
OkeeGuy's Avatar
OkeeGuy
Default Re: new side pipes! (Red73)
[QUOTE]
actually on my pipes its the "tab" to the right that had to be cut off...
how much? well...you can install your pipes and then cut it off...
they DO fit without cutting but the pipe will be up against it enough so that it does need to be trimed a little...
the main thing that has to be trimed, unfortunatly, is the "rocker panel" trim piece as it is impossible to put back on with the pipes in place...
tomorrow i will have my car up on jack stands again and i will take some pics of the mounting and hook up...
here is a pic i took yesterday...im sorry for the quality...i dont know whats up with my camera... :mad
ill get it figured out and take some more pix tho...
also...thanx again for the possitive comments and compliments... :)
[Modified by SIGNGUY, 11:01 AM 12/14/2003]
Old Dec 14, 2003 | 12:35 PM
EDDIEJ82's Avatar
EDDIEJ82
Signguy yours look great, but I still love my hookers :cheers:
Chuck mine went in with no problem and no cutting (might have got lucky)
Either way Sidepipes are way cool !!!!
Old Dec 14, 2003 | 06:00 PM
  #33
OkeeGuy's Avatar
OkeeGuy
Default Re: new side pipes! (EDDIEJ82)
i may have had to trim because i wanted them as high as possible for clearance...for the floor jack as well as other things... :D
Old Dec 14, 2003 | 09:45 PM
  #34
ry's Avatar
ry
:cool:
Old Dec 14, 2003 | 11:39 PM
  #35
corvettemaster's Avatar
corvettemaster
looks great :thumbs: i'm hoping to have a set of black hooker's on my beige 81 this summer
Old Dec 15, 2003 | 01:53 PM
  #36
markd's Avatar
markd
Default Re: new side pipes! (corvettemaster)
I have always wanted to put side pipes on my '75 vert but never did anything because of the issue of the catalytic converter, or more specifically the lack of one. Is there somthing I'm missing?
Old Dec 15, 2003 | 02:23 PM
  #37
EricU's Avatar
EricU
Default new side pipes! (SIGNGUY)
Two questions for you Hooker side pipe guys.
1) Where did you get your pipes?
2) Is 1 7/8" diam. primarys the only ones available from Hooker?
I have been going back and forth on whether or not to get side pipes, but after seeing so many pics on this forum, well got to have em! I will be gettingh the black pipes so I can weld in a 02 bung, then have them coated.
My car is at a shop having a hood made and some minor body work done. Then the side pipes, 5-speed and hopefully get it painted before spring!
Thanks, Eric.
To new side pipes!
Old Dec 16, 2003 | 02:08 AM
  #38
johnnybrewmeister's Avatar
johnnybrewmeister
very nice indeed!
I think I'll add this to my list of "upgrades"...though I have a pretty long timeline for this type of thing.
Still, very nice.
Old Dec 16, 2003 | 05:07 PM
  #39
frank0075's Avatar
frank0075
Default Re: new side pipes! (johnnybrewmeister)
I had the chrome hooker side pipes on for about 10 years, loved them. Finally got a hole in one of the side pipes so I took them off and put a stainless system on. I still have the hooker headers and both mufflers in my attic if anybody is interested in them. Might be able to powder coat them and buy new side pipes.
Old Dec 16, 2003 | 05:55 PM
  #40
AGVI's Avatar
AGVI
Canadian Events Coordinator
Default Re: new side pipes! (frank0075)
I like the look of the stock exhaust on the non chrome bumper cars :smash:
...but hey, you like it, you like it! :party:
