Are compression fittings acceptable on steel fuel lines?
I'm adding a nitrous kit and need to incorporate a fuel pressure saftey switch, a in line filter and a tee fitting all between the mechaical fuel pump and the carb. Fuel preesure should be no more than 8 psi. Is there any reason I shouldn't use a compresion fitting( 3/8 pipe to 3/8 tube) off the bottom of the fuel pump if it works out better going that way. I've seen compression fittings used in hydraulic systems running up to 1000 psi. Any information would be appreciated.
Re: Are compression fittings acceptable on steel fuel lines? (74ZZ430)
i ve done it but it ain't the right way... gas is so much thiner(don't remember
the correct term) it can seep,wick, what ever you want to call it easyer than
oils is it a copper compression on the steel line??? if so it will work
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
You can get hydraulic compression fittings anywhere hydraulic hoses are made. These fittings are much more substantial then "plumbing" compression fittings. I wouldn't be afraid to use them. They are normally steel (not brass) and use 2 compression sleeves.
I have used them in fuel lines before without a problem. My 1/2 inch stainless main line has one stainless compression fitting in it and it has never leaked even after taking it apart many times.
Re: Are compression fittings acceptable on steel fuel lines? (markdtn)
I used compression fittings for the tripower carbs on my firebird because of the close quarters, but if you learn to make flares, it's a skill you'll keep for future projects. Plus it's an excuse to buy another tool! Joe
[Modified by joe73vette, 6:58 PM 12/18/2003]
Location: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: Are compression fittings acceptable on steel fuel lines? (joe73vette)
My fuel injection system uses compression fittings when going from hard line to hose. I go from aluminum tubing to a -06 fitting, then from there to -06 hose to the next fitting.
It holds up to 40 psi. I had one leak. Just tightened up the fitting and the leak is gone.
St. Jude Donor '11-'12-'13,'19-'20
I've always been taught that you don't **** around with the pressure side and always use hardlines and flared fittings, so thats what I do. ymmv! Flaring is getting to be a lost skill . I thoroughly enjoyed learning it via my own projects.
Fuel pressure for carbureted cars is low (under 10 psi) and [metal]compression fittings have WAY more capability for holding pressure than that. Any metal comp fitting is very capable for sealing EFI pump pressures, too.
I would NOT use a polymer seal or synthetic rubber seal compression fitting with fuel.
