Valve Timing Question
Old Dec 30, 2003 | 08:46 AM
Boofers's Avatar
Boofers
Default Valve Timing Question
I found stock specs on the valve timing of my engine. They are:
Inlet Opens - BTC ...... 28 degrees
Inlet Closes - ABC ..... 72 degrees
Duration .................... 280 degrees
These are listed in Crankshaft degrees.
Anybody know if I can somehow calculate the cam duration @ .050"?
[Modified by Boofers, 10:41 AM 12/30/2003]
Old Dec 30, 2003 | 11:09 AM
1979toy's Avatar
1979toy
Default Re: Valve Timing Question (Boofers)
The @.050 duration is a function of the ramp of the cam and will not be the same from one mfg. to another. Weather it is a roller cam or a flat tappet cam will also change the @.050 numbers. You can get close to your numbers by shopping with both a Jeg's and a Summit catalog. Find your duration on a cam in the Jeg's catalog and then look the same cam up in the Summit catalog.
Old Dec 30, 2003 | 12:12 PM
lars's Avatar
lars
Boofers -
Due to different ramp rates, you can't calculate duration at .050 based on advertised duration - you have to measure it.
To Valve Timing Question
