Heat riser questions ?
Old Jan 4, 2004 | 06:29 AM
mpeter's Avatar
mpeter
Default Heat riser questions ?
Hi,
Why is the purpose of the heat riser? Why is it only on the passenger side of the exhaust system?
I have a lower compression rate on the passenger side of the engine, could the heat rise be the cause?
Thanks for your usefull answers,
Mike
Old Jan 4, 2004 | 07:01 AM
Fleetwood's Avatar
Fleetwood
Default Re: Heat riser questions ? (mpeter)
http://www.thebugshop.org/bsfqrisr.htm
As for your compression,I can't see how the heat riser will have any effect.
Old Jan 4, 2004 | 08:09 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
When the engine is cold, the heat riser partially occludes the exhaust flow, directing it "upward" through the intake manifold, warming it and the fuel/air charge going through the carburetor. This makes for smoother running till the engine warms up.
With the riser closed or partially closed, the exhaust gasses pass upward from the passenger side, through the intake manifold, and are exhausted through the drivers side system. That's why there is only a heat riser on one side.
As the engine warms up, the thermostatic coil on the heat riser opens, allowing the "flapper valve" to open. This then allows free flowing exhaust. Should have absolutely NO effect on the compression ratio. Chuck
To Heat riser questions ?
