need help with electrical
Old Jan 4, 2004 | 10:04 PM
feb18blacksunday's Avatar
feb18blacksunday
From: Boone NC home of 3peat National Champs ASU Mountaineers
St. Jude Contributor
Default need help with electrical
It all started when I replaced the turn signal flasher. There was a resistor looking thing located under the flasher, does it need to be replaced too. I keep blowing tail light and instrument panel fuses. Any Ideas?
Old Jan 4, 2004 | 10:28 PM
wombvette's Avatar
wombvette
Default Re: need help with electrical (feb18blacksunday)
No, but you may hear a little poping in your radio when you use the signal.
Old Jan 4, 2004 | 10:38 PM
feb18blacksunday
Default Re: need help with electrical (wombvette)
No popping. Radio unaffected.
Old Jan 4, 2004 | 10:54 PM
Fleetwood's Avatar
Fleetwood
Have you removed this " resistor looking thing" which sounds like a capacitor.
What year is your car?
Neil.
Old Jan 4, 2004 | 11:12 PM
feb18blacksunday
Default Re: need help with electrical (Fleetwood)
79 Pulled it off and put it back on after Forum member sent me a picture. It worked ok for a while then lost the fuses last nite. :mad
Old Jan 5, 2004 | 12:14 AM
Fleetwood's Avatar
Fleetwood
If it's a capacitor,they were used in the old days for radio interference supression before FM reception.Remove it it's not needed.If you are still blowing fuses,you may have a short somewhere.Bur try removing the cap first.
Neil.
Old Jan 5, 2004 | 12:44 AM
LAvetteman's Avatar
LAvetteman
What problem were you having before changing the flasher??
Old Jan 5, 2004 | 11:33 PM
feb18blacksunday
Default Re: need help with electrical (LAvetteman)
Had no turn signals.,before the flasher went out . Now it just blows fuses.
Old Jan 6, 2004 | 03:37 AM
Fleetwood's Avatar
Fleetwood
Did you remove the capacitor? If so are you still having problems?
Neil.
Old Jan 8, 2004 | 11:54 PM
LAvetteman's Avatar
LAvetteman
Flasher may not have been bad. May have another problem. Try changing the bulbs and inspecting the sockets for corrosion or broken insulators.
Old Jan 9, 2004 | 07:59 AM
Jim Shea's Avatar
Jim Shea
On my 1975, somebody had wired a capacitor across the two leads on my brake light switch. It didn't blow fuses when it went bad, it just stopped the brake lights from working. It looked as if Bubba or a dealer had installed it. Definately not from the factory. I removed the capacitor and everything was fine.
BTW I also had a capacitor attached to the flasher as you described. I haven't noted any snapping or other problems since removing it also.
Old Jan 10, 2004 | 12:51 AM
feb18blacksunday
changing the flasher cured the problem with the flashers. I think the resistor thing is the problem.
Old Jan 10, 2004 | 12:52 AM
feb18blacksunday
Default Re: need help with electrical (Jim Shea)
removed mine too but the taillight instrument problems started. I'll try a new flasher.
Old Jan 10, 2004 | 07:35 AM
ductape's Avatar
ductape
Cruise-In V Veteran
Was this flasher exchange a simple pop-out-pop-in deal? Did you have to remove ANYTHING to get to it? And when do the fuses blow? What's going on?
Was the car like this when you got it, or was everything fine, then, one day no flashers and now this. :confused:
To need help with electrical
