Under Hood Temperatures?
Old Jan 8, 2004 | 06:16 PM
'69CoupeDude's Avatar
'69CoupeDude
Default Under Hood Temperatures?
Has anybody measured under hood (carb inlet) temperatures? I'm trying to determine potential performance gains by running cold air to the carb. I have a small block with uncoated headers.
Old Jan 11, 2004 | 07:59 PM
flynhi's Avatar
flynhi
Default Re: Under Hood Temperatures? ('69CoupeDude)
The rule of thumb is that you will pick up 1% HP for every 10 degrees F that you drop the inlet air temp.
Old Jan 11, 2004 | 08:01 PM
norvalwilhelm's Avatar
norvalwilhelm
I found that wrapping my headers really cut down on underhood temperatures. Then I got carried away and put my carbs way up in the air.
Old Jan 12, 2004 | 12:13 AM
Cookwithvette's Avatar
Cookwithvette
My fuel injection system measures intake air temp. With outside air around 80 degrees the intake air was measureing around 111. That's cruising with an open cowl induction hood. (no electronic flapper) I don't have any sort of mechanism that keeps my engine breathing only through the cowl so some underhood air is being used. I would guesstimate that on a warm summer day a header-equipped car would see underhood temps in the 145 degree range. I base that just on how things (hoses, brake booster) feel after driving. Hot enough to be very uncomfortable but not enough to cause a burn.
To Under Hood Temperatures?
