Hydroboost install questions....
Old Jan 11, 2004 | 01:23 AM
79VetteMike's Avatar
79VetteMike
Default Hydroboost install questions....
Hi all- Today I finally got the engine and trans in the car-after 4 months of detailing and new suspension, etc. Anyway, I put the hydroboost on several weeks ago(excluding the lines). Today as I'm looking through my hardware, I find the little push-rod that typically goes from the master cylinder to the brake booster. Was I suppose to put that push-rod on the hydroboost unit? I forgot what it looked like between the booster and master cylinder, and I don't want to screw up. I did an initial brake bleed a week or two ago and it didn't seem like the fluid was flowing the way it should. I have rebuilt o-ring calipers and all SS lines-hard and flexible. Finally, my buddy was hooking up the hydroboost lines to the power steering while I was working on the BTO trans hook-up. Anyway, the lines are moving with the slave cylinder. It seems excessive. Is this normal? Thanks in advance....Mike
Old Jan 11, 2004 | 01:28 PM
79VetteMike
Default Re: Hydroboost install questions.... (79VetteMike)
Anyone?
Old Jan 11, 2004 | 01:38 PM
1979toy's Avatar
1979toy
I bought my Hrydo-Boost with a new master cylinder and it came assembled. If you even think that a part is missing in there I would recommend that you take it apart and verify that all of the parts are in place before driving the car. There are 2 differant length rods used on the master cylinder depending on the master cylinder used and the year of the car. Could you have been sent 2 so that you could install the correct one?
The steel braided lines are stiffer than the rubber lines that they replace but I had no trouble aligning mine so that they didn't drag on anything.
Old Jan 11, 2004 | 02:10 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Hydroboost install questions.... (1979toy)
if all is well the rod should already be in there
Old Jan 11, 2004 | 02:16 PM
79VetteMike
Default Re: Hydroboost install questions.... (Twin_Turbo)
thanks dudes. any problems with the lines being a very tight fit and alot of movement with them when the wheels are moveing laterally? thanks again.
Old Jan 11, 2004 | 03:06 PM
Pete76Shark's Avatar
Pete76Shark
I had the correct rod come with the kit caused I called and talked to them first. The new lines are stifferbut so long as they clear everything you will be ok.
To Hydroboost install questions....
