Nose emblem???
Old Jan 11, 2004 | 03:54 AM
Fleetwood's Avatar
Fleetwood
Default Nose emblem???
I have replaced the front clip on my car,unfortunately there are no fixing holes for the front nose emblem.Does anyone have the measurements of the holes for me.
Thanks Neil.
Old Jan 11, 2004 | 07:19 AM
Jvette73's Avatar
Jvette73
Default Re: Nose emblem??? (Fleetwood)
Use the emblem to make a template out of paper or thin cardboard. Tape it down over the correct location, mark the holes and drill.
Old Jan 11, 2004 | 08:45 AM
markdtn's Avatar
markdtn
Default Re: Nose emblem??? (Jvette73)
Look at your AIM to find where it goes and hole size.
Old Jan 11, 2004 | 10:06 AM
rponfick's Avatar
rponfick
Have you considered just leaving it off? I'm in the same boat you are,but just plan to keep the front end clean. It can be added at any time if you want. Just a comment.
Old Jan 11, 2004 | 10:39 AM
Fleetwood's Avatar
Fleetwood
Default Re: Nose emblem??? (markdtn)
The AIM manual does not give the measurements for drilling the holes on the nose,assume original front clips were pre-drilled.
rponfick, Seeing as I bought a new one I think I would like to have it fitted.
Thanks Neil.
[Modified by Fleetwood, 9:42 AM 1/11/2004]
Old Jan 11, 2004 | 11:10 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Fleetwood, I just went out and measured mine. I have the emblem out and measured from the hood opening down to the emblem holes. The holes are 11 inches down from the opening. Convert that to metric and you are set.
Old Jan 12, 2004 | 12:35 AM
Fleetwood's Avatar
Fleetwood
Default Re: Nose emblem??? (Eddie 70)
Thanks Eddie,Thats what I need to know. :yesnod:
To Nose emblem???
