82 Remove CAT-Air Pump-Installing a "TEST PIPE."
Old Jan 21, 2004 | 09:53 PM
MN-Brent's Avatar
MN-Brent
Default 82 Remove CAT-Air Pump-Installing a "TEST PIPE."
Ive got one coming from EBAYs only supplier RMT.
For the Air Pump removal, if you remove it, what about the air lines going into the OEM exhaust "headers".
Can they be plugged with a rubber cap up further away from the heat?
All comment welcome.
Brent...
Old Jan 21, 2004 | 10:01 PM
Stoge's Avatar
Stoge
Default Re: 82 Remove CAT-Air Pump-Installing a "TEST PIPE." (MN-Brent)
I wonder if you could just use a small bolt with some good anti seize compound?
Old Jan 22, 2004 | 05:24 AM
stickboy's Avatar
stickboy
On my '81 with the tubular manifold the AIR tubes were welded in place. If your happend to be screwed in you can use a pipe plug. Also if your AIR pump is computer controlled the check engine light will come on if it's not plugged in. But you could probably fix that with a resistor, but I never bothered to figure out the size needed. My computer was ripped out this winter.
Old Jan 22, 2004 | 10:08 AM
markdtn's Avatar
markdtn
Default Re: 82 Remove CAT-Air Pump-Installing a "TEST PIPE." (stickboy)
When I put TPI in my 69 I used C4 manifolds/headers. I took a hand grinder and cut the AIR "rakes" off as close as I could to the tubes. I took a drill that was just slightly larger than the tubes and drilled them out. Then I welded the holes shut. Hit them with a wire brush and they they look great. Got rid of the AIR tube extending into the header tube.
Old Jan 22, 2004 | 07:42 PM
terry82's Avatar
terry82
i have removed my air pump .did not get a check engine light.for now i caped off the lines coming off the headers .you could use anything that will fit into the rubber hose.i dont want to cut my lines off the factory headers ,i may need or want them back later[emissions testing or may be the next owner will want or need them]the factory headers are not that good they are small ,so i would like to take them off and put on a good set that are more free flowing and that have been jet hot coated . my factory cat is still there but has been modifyed [hollowed out]it does help performance.
Old Jan 22, 2004 | 08:38 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: 82 Remove CAT-Air Pump-Installing a "TEST PIPE." (terry82)
remove the checkvalves and cap them off with a pipe plug:
Old Jan 23, 2004 | 12:55 AM
MN-Brent's Avatar
MN-Brent
Default Re: 82 Remove CAT-Air Pump-Installing a "TEST PIPE." (Twin_Turbo)
Thanks for the replies.
Twinnie-double thanks for the photo.
I looked at the CFI Vault too and found alot of good info on emissions removal steps. This photo speaks a 1000 words as to how to handle the air tubes. :cheers:
Is it recommended to use teflon tape sealant on the threads?
Brent...
Old Jan 23, 2004 | 06:11 AM
Twin_Turbo's Avatar
Twin_Turbo
Use copper paste, that'll keep them from rusting stuck
Old Jan 23, 2004 | 04:05 PM
terry82's Avatar
terry82
t t all i see is a red x
Old Jan 23, 2004 | 04:07 PM
Twin_Turbo's Avatar
Twin_Turbo
the server is down again :( when it's back up the pic will be visible.
To 82 Remove CAT-Air Pump-Installing a "TEST PIPE."
