Bouncy Tach
Old Feb 4, 2004 | 08:29 PM
PewterMetallic98's Avatar
PewterMetallic98
Default Bouncy Tach
My tach has just recently decided to go crazy. When I punch it the tach starts bouncing around everywhere. If I slowly accelerate up to 2K rpms it wont do it anything but as soon as it gets higher then it starts bouncing really bad. What could be the problem? I'm lost on where to start. :confused:
Old Feb 4, 2004 | 10:42 PM
PewterMetallic98
Default Re: Bouncy Tach (ElectronBlueC3)
btt
Old Feb 4, 2004 | 10:45 PM
l2vette's Avatar
l2vette
It could be either the tach drive gear or the cable. I would check the cable first to see that it has no sharp bends and turns smoothly in the housing. Good Luck.
:cheers:
Old Feb 4, 2004 | 10:58 PM
CharlieF's Avatar
CharlieF
Default Re: Bouncy Tach (l2vette)
:cheers:
I would check the cable for binding...I believe it takes a pretty sharp bend coming out of the distributer.
Old Feb 4, 2004 | 11:00 PM
78 Vette's Avatar
78 Vette
Tach drive in a 81?
Old Feb 4, 2004 | 11:12 PM
l2vette's Avatar
l2vette
Default Re: Bouncy Tach (78 Vette)
OOPS! I guess not.
Old Feb 5, 2004 | 12:14 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
My tach was doing funky things for a while. It would rev smooth to 2K, then start working back to 0, then back up again.
I traced the problem to the tach filter mounted on the intake manifold. I don't think my new fuel injection system and coil liked it much. Bypass yours and see if it works better.
Old Feb 5, 2004 | 12:23 AM
PewterMetallic98
Default Re: Bouncy Tach (BSeery)
Well I don't have any of the original motor in the car, so im still finding out where things are and what needs to be hooked up. I'll look for a tach filter if i can find one and maybe a crimp or two in the cable. Thanks for all the help guys! :yesnod:
Old Feb 5, 2004 | 12:27 AM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
Could be the tach circuit board too. These are known for going bad after 20-25 years.
(along with most of the rest of the car too) :lolg:
Good Luck!
:seeya
Old Feb 5, 2004 | 01:46 AM
DMONSVETTE's Avatar
DMONSVETTE
Start with the tach filter and then the speedo/tach circuit board. Check this link
http://forums.corvetteforum.com/zerothread?id=647286
Old Feb 5, 2004 | 04:14 AM
Pauld's Avatar
Pauld
Default Re: Bouncy Tach (DMONSVETTE)
My '81 does axactly the same as yours!! I think it is a faulty tach board, there is power going to it because it moves, but just like yours it is not working right at all!!! If you find anything different, I would appreciate the advice.
And by the way, when i got my '81 it wasn't working at all, i bought a tach board from a place in the UK and it does what yours does now. I spoke to some one in your country( i think it was called Redline Gauges or something like that) and he was very helpful and said he thinks it is a faulty tach board and explained there was a bunch manufactured that were in circulation that caused the exact problems mine was showing. :cheers:
Old Feb 5, 2004 | 04:38 AM
theoUK's Avatar
theoUK
A bouncy needle sounds more like you DON'T have a tach filter hooked up in the first place. Or you've got one, but the ground's bad. Follow the tach wire thru from the distributor, the filter's supposed to be bolted to the inlet manifold. Some people move them, but fail to keep them grounded by bolting them to something insulated. If it is missing, I'd try to get hold of one before you fry your board. There's a guy who makes new ones somewhere on the web, but they don't look original. Can't remember the site, but his name's Rodney Dickman.
The filter only contains a couple of resistors and caps, nothing too complex.
Good luck!
Old Feb 5, 2004 | 04:52 AM
Pauld's Avatar
Pauld
Default Re: Bouncy Tach (theoUK)
Theo, Mine did this with the tach filter in place and I was told to remove the tach filter. Alot of people have said that you can remove them with no problem. When i removed it, it made no difference. :confused:
Old Feb 5, 2004 | 04:58 AM
theoUK's Avatar
theoUK
Default Re: Bouncy Tach (Pauld)
Hey paul, I'm in the middle of writing you an email!
It's on its way....
:cheers:
Old Feb 9, 2004 | 12:01 PM
theoUK's Avatar
theoUK
PaulD, Did you get my email??
Can I help you get your tach working properly again?
:cheers:
Old Feb 9, 2004 | 12:05 PM
Pauld's Avatar
Pauld
:cheers:
Hi theo, got your email, thanks for that. I will probably take you up on your kind offer once I have sorted out some other stuff. A few projects on the go at the moment, keeps me busy!! :D :D :cheers:
Old Feb 9, 2004 | 01:25 PM
theoUK's Avatar
theoUK
Cool, just let me know if you do want to try a new chip out. I have access to all the equipment needed to test the system, so we'll see what happens. I guess as long as it works (even if not quite right) then like you say, there are many many other things to be looking into. The joys owning a car that's pushing its quarter century!
(Hang on, I've just made my quarter century, and nothing's fallen off me yet!) Famous last words...
:cheers:
To Bouncy Tach
