Frame question
Old Feb 6, 2004 | 06:20 PM
Jeffski's Avatar
Jeffski
Default Frame question
I may have a line on a 82 vette frame, my car is a 77. Will the 82 frame fit?
Not worried about matching numbers just if it will fit.
Thanks :cheers: :cheers:
Old Feb 6, 2004 | 07:16 PM
Jeffski's Avatar
Jeffski
Default Re: Frame question (Jeffski)
Nobody?
Any information would be appreciated.
Thanks :cheers:
Old Feb 6, 2004 | 07:24 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
There are some minor differences. But I think, and I hope someone who really knows will chime in, I think it will work.
Old Feb 6, 2004 | 07:38 PM
crf311's Avatar
crf311
I think the rear end mounts differently. Not sure?
Old Feb 6, 2004 | 07:50 PM
lbell101's Avatar
lbell101
Default Re: Frame question (crf311)
http://www.71corvette.com/frames.html
Old Feb 6, 2004 | 08:06 PM
Jeffski's Avatar
Jeffski
Default Re: Frame question (lbell101)
Thanks, thats a great site. Looks like the rear diff carrier is different. Would mine bolt in to this new setup?
Thanks :cheers:
Old Feb 6, 2004 | 08:35 PM
MikeC's Avatar
MikeC
The rear end mount is significantly different, unless you are a good fabricator and welder, you better pick up the rear end with it.
Old Feb 6, 2004 | 08:39 PM
NHvette's Avatar
NHvette
Default Re: Frame question (MikeC)
The rear carrier mounting is different, yeah. You can buy teh tophat plates
that the 77 crossmember moutns to and have someone weld them in.
Another problem of equal importance is the gas tank mounting. They moved
the tank rearward when the rear fastback glass was introduced. Again, a good
welding shop should be able to modify this easily.
For an easy fit, you need a 74-77 frame. Even those may have minor differences, but nothing to cut and weld.
:seeya
Old Feb 6, 2004 | 09:17 PM
74droptop's Avatar
74droptop
Default Re: Frame question (NHvette)
:iagree:
Old Feb 6, 2004 | 10:48 PM
Jeffski's Avatar
Jeffski
Thanks Guys, Looks like I'll keep looking.
:cheers:
To Frame question
