Intermittent starter problem
Old Feb 10, 2004 | 11:17 AM
vvv90's Avatar
vvv90
Default Intermittent starter problem
When I turn the key sometimes the starter motor revs real high like it's not catching the flexplate. Then I turn the key again and it catches and starts the car.
I'm guessing it's the bendix no pushing the gear out.
Just though I'd post unless it's the possibility of being something else before I replace the starter.
Thanks.
Old Feb 10, 2004 | 12:24 PM
mrvette's Avatar
mrvette
Default Re: Intermittent starter problem (vvv90)
NO chance for error, it's the bendix.....make damn sure you don't confuse any wiring.....there is a ground wire down there somewhere with a 3/8 eyelet on it...black about 10 ga or so....it's a ground, not to the battery post....
GENE
Old Feb 10, 2004 | 05:58 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Default Re: Intermittent starter problem (mrvette)
Me too! I'm pretty sure it's just bad connections in my case, and possibly yours too, because sometimes it does work.
Old Feb 10, 2004 | 06:11 PM
vvv90's Avatar
vvv90
Default Re: Intermittent starter problem (RUXperienced)
Well, I'll clean up the connections before I replace and see if that does anything. If not, It's only $35 with a lifetime warranty for a Delco from Murrays.
:cheers:
To Intermittent starter problem
