Does anybody make?
Old Feb 16, 2004 | 09:47 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Does anybody make?
a large port vortec style cylinderhead? like in the 210-220 range?
Old Feb 16, 2004 | 10:01 AM
Fevre's Avatar
Fevre
Default Re: Does anybody make? (Guru_4_hire)
Believe that is what the Fast Burn GM heads are:
Vendor: GM Performance Parts
Product Line: GM Performance Parts Fast Burn Cylinder Heads
Material: Cast Aluminum
Finish: Cast
Fast burn for high performance.
Chevrolet: 1958-2000 283-400, 62cc combustion chambers, 200cc intake runners, 2.00 in./1.55 in. diameter intake/exhaust valves, 1.32 in. diameter single valve springs, angled spark plugs, assembled, Fast Burn cylinder head
This fully assembled, CNC-machined aluminum Fast Burn cylinder head is designed for 1958-2000 283-400 c.i.d. Chevy V8s. It quickly and completely burns the air/fuel mixture, ensuring higher cylinder pressure and more power. No additional porting is required--GM Performance Parts' Cast-Ported technology gives this head maximum performance right out of the box. It's drilled and tapped for both Vortec and raised port manifolds, accepts flange mount or centerbolt-style valve covers, and will support in excess of 500 HP. The head features 62cc combustion chambers, lightweight 2.00 in. intake valves and 1.55 in. exhaust valves, LT4-style intake ports, a .400 in. deck, CNC-machined rocker rails, "D" shaped 78cc exhaust ports and runners, 210cc raised runner intake ports, lightweight valve spring retainers, screw-in 3/8 in. rocker studs, and angled spark plug holes.
http://store.summitracing.com/search...part=fast+burn
Old Feb 16, 2004 | 10:12 AM
Guru_4_hire
Cruise-In V Veteran
Default Re: Does anybody make? (Fevre)
Etecs from edelbrock too I think. Just wondering about other manufacturers though
Old Feb 16, 2004 | 10:51 AM
Guru_4_hire
Cruise-In V Veteran
Anybody know anything about this?
GM advertises their flow numbers as above 270 Where as sallee tested some production heads and had found their numbers to be around 238
http://www.sallee-chevrolet.com/Fast...der_Heads.html
Anybody have a clue on this one?
To Does anybody make?
