STUCK! help needed..
Old Feb 21, 2004 | 08:08 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default STUCK! help needed..
I'm trying to get my dash out, I disconnected as many vaccum hoses as I could find, the light 'switch' another funky electrical harness, speedo/tach cables and even the steering column bolts and the damn thing wont budge. this is as far as I got..
click to enlarge
what do I have to do :confused:
[Modified by Corz, 8:08 PM 2/21/2004]
Old Feb 21, 2004 | 08:16 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: STUCK! help needed.. (Corz)
Boy you really made a mess this time. :lol: I can't help you with the dash. Removing the dash on my Vette is a recurring nightmare I keep getting. :lolg:
Old Feb 21, 2004 | 08:17 PM
Corz's Avatar
Corz
Default Re: STUCK! help needed.. (Jughead)
no sheeet :lol: I'm trying to clean the mess in my engine bay and it moved to the interior :bb
Old Feb 21, 2004 | 08:42 PM
LemansBlue68's Avatar
LemansBlue68
Do you have the three bolts loose from the steering column up near the support bracket? If so, you may have to loosen the bolts at the floorboard so that the column can drop down a bit. I had the column completely out when I removed my dash pannel and it came right out. Your column definitely is not lowered enough for that panel to come out.
Good luck!! :thumbs:
Old Feb 21, 2004 | 08:51 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Corz, I know this sounds like more work than necessary but I have never had much luck taking out the driver side dash without removing the top dash and lowering the steering column. To get the top dash out you have to remove the top and both windshield post trim pieces as well as the passenger side dash. Be carefull to remove all the screws from the top of the center console bezel and the brackets on the underside of the top dash..... it is very fragile. pretty sure you need to remove the plastic side kick panels as well to get the driver and passenger dash out.
After you have the top dash out you will be able to get to the most of the back of the driver side dash from either the top or the bottom. take your time and everything should be pretty obvious. The dash is held pretty tight by the tach and speedometer cables.
This is probably my most "not fun" thing I have done on my C3's
Good luck, and don't hesitate to ask more questions.... is this your first time in the dash?
Bullshark
[Modified by Bullshark, 8:01 PM 2/21/2004]
Old Feb 21, 2004 | 09:09 PM
Corz's Avatar
Corz
Default Re: STUCK! help needed.. (Bullshark)
wait a minute.. there's three more bolts to the column???? son of a !!!!!! I'm such a dumbazz.
its not my first time in the dash itself.. but my first time trying to get the drivers side out
Old Feb 21, 2004 | 09:11 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
:blueangel:
:D
Old Feb 21, 2004 | 09:13 PM
Corz's Avatar
Corz
Default Re: STUCK! help needed.. (Avette4me)
shut up Albinogorillalover4me :lol: :lol:
Old Feb 21, 2004 | 09:27 PM
GTR1999's Avatar
GTR1999
You have to drop the steering column down in your lap as you sit there at the wheel. Loosen the bolts under the column and at the firewall. Disconnect the speedo and tach ,vacum lines, dash lamps,and slowly pull forward and out.
I'll be working on my S10 around 1-2:00 tommorow if you want to see my 69 with the dash out.
Gary
Old Feb 21, 2004 | 10:07 PM
sjr1971's Avatar
sjr1971
Why does your pix look familiar? I have my '71 stripped to the firewall. You will have to pry the wire harness, witch is held by soft metal clamps, away from your drivers panel, pull out all the panel lights, then pull the panel towards you and up. Mark your pneumatic lines and elect cons. that aren't odvious. The bulbs are color coded. This is the second time I have done this.
[Modified by sjr1971, 3:16 AM 2/22/2004]
Old Feb 21, 2004 | 10:39 PM
Corz's Avatar
Corz
Default Re: STUCK! help needed.. (gtr1999)
Thanks guys, Gary, I'll swing over anyway to BS..
hmmmmm should I do phantom guages :reddevil
Old Feb 22, 2004 | 03:00 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
:withstupid: :thumbs:
Old Feb 22, 2004 | 03:04 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
No. but you should try to mount them upside down like this picture....now that would be cool :p:
Old Feb 22, 2004 | 03:24 AM
Corz's Avatar
Corz
Default Re: STUCK! help needed.. (Desertdawg)
what fun would that be? :hat
Old Feb 22, 2004 | 11:40 AM
comp's Avatar
comp
WHAT FUN ? try gettin' it around the column :lolg: :lolg: :lolg:
Old Feb 22, 2004 | 11:46 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: STUCK! help needed.. (comp)
Cory, could you flip your dash pad over and take a pic of the speedo and tach mounts for me.
Old Feb 22, 2004 | 12:31 PM
Corz's Avatar
Corz
Default Re: STUCK! help needed.. (Eddie 70)
sure, gimme a couple minutes and I'll take some pics for ya :cheers:
To STUCK! help needed..
Old Feb 22, 2004 | 01:23 PM
Corz's Avatar
Corz
:cheers:
btw, does anyone know where this hose goes to? it was blocked off when I got to it
Old Feb 22, 2004 | 01:51 PM
sjr1971's Avatar
sjr1971
Just checked that blocked hose on mine. It goes to one of the over ride switches under the speedo/ tach panel you removed. The small one to the right. I think it for the wiper door manual over ride but don't remember.
Old Feb 22, 2004 | 02:08 PM
pillowmeto's Avatar
pillowmeto
Default Re: STUCK! help needed.. (sjr1971)
well if you mounted them upside down then atleast they woudl be in the order of a normal car.
I remember when i first got my 76 and kept looking at the wrogn gauge cause all the other cars id had were the opposite
MAtt
