factory alarm
Old Feb 21, 2004 | 09:40 PM
NOTHIN'LIKE'A'69''s Avatar
NOTHIN'LIKE'A'69'
Default factory alarm
what have you guys done with your factory alarm.... last owner of mine had a chapman lock set up in the hole connecting to nothing :confused:
any one try to install some type of key activated kill switch back there??? Any ideas??
:chevy
Old Feb 22, 2004 | 08:34 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: factory alarm (NOTHIN'LIKE'A'69')
It's fairly straight forward to get your factory alarm working. There's a wiring diagram in the "option" section of your 69 AIM...don't remember the number. The flasher and relay are located down by the jack in the storage compartment. Hope this helps. Chuck
Old Feb 23, 2004 | 10:42 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
It's a fairly simple design. A number of switches run in series. Any switch breaks the alarm goes off. I found a wiring diagram for my '78 posted in the web. With a little work you may find the diagram for the '69.
To factory alarm
