Help diagnosing power window problem
Old Aug 19, 2022 | 09:52 PM
woodsdesign's Avatar
woodsdesign
Originally Posted by Hellah fresh
Rise this thread back from the dead lol. So my 81 driverside window has stopped working. One thing I noticed about the driver Window was that it always rolled down super fast compared to the passenger side.
When I click the window button up or down I can hear a slight "tic" from the door. To whomever posted in here have you found your problem?
Also look at your battery gauge. if you see it go to the left when you move the switch that means that the window is jammed. The window goes down too fast, the gear flexes and gets cockeyed. Usually, if you take off the door panel and loosen the regulator bolts it will pop back in place. If it doesn't then you got to get creative. I taped a long handle on a 1/4" drive and managed to get to window glass removed.
