help tuning quadrajet
Old Mar 20, 2004 | 09:53 PM
drm78's Avatar
drm78
Default help tuning quadrajet
I replaced cam and added headers set valves and timing as per lars paper everything went perfect engine fired first pop. Im going to change the advance on the dist. tomorrow and reset timing as per lars. I took it for a ride today engine runs real smooth but it doesnt feel like the four barrel is kicking in. When i take air cleaner lid off and hit throttle back flaps dont open. Are they suppose to? Ill will need help with jetting and choke setup if anyone has sugestions in that area any help will be apperciated. Also removed egr . On my choke housing there is a vacum line hooked to it does this have to be hooked up and if so what port does it go to . thanks for any help DRM78 :banghead:
Old Mar 21, 2004 | 10:34 PM
sjr1971's Avatar
sjr1971
Default Re: help tuning quadrajet (drm78)
Q-jets have a mechnical secondary lockout that is locked until the chock is fully open. Its a metal tab that is visable on the passenger side of the carb just behind the throttle shaft.
Old Mar 21, 2004 | 11:35 PM
page62's Avatar
page62
Lars has a QJet tuning paper over at http://www.corvettefaq.com -- as with all his stuff, it's highly recommended. Also get a copy of the book Rochester Carburetors by Doug Roe.
The secondary top flaps will not open when you open the throttle. But if you blip the throttle to high rpms with the engine running, you'll see them pop open momentarily.
Old Mar 22, 2004 | 09:24 AM
page62's Avatar
page62
Default Re: help tuning quadrajet (page62)
I stand corrected. According to Lars, you can't "wing the throttle" to see the secondaries open...
Old Mar 22, 2004 | 09:29 AM
isosceles's Avatar
isosceles
.....this happens on mine. If Lars says it doesn't happen, I'd imagine something is a tad askew with my car. He's forgotten more than I'll ever learn about carbs.
Old Mar 22, 2004 | 09:43 AM
JBR's Avatar
JBR
I don't beleive the secondary air valve can be made to open while sitting in the driveway. You might want to check the secondary spring tension. :cheers:
Old Mar 22, 2004 | 10:05 AM
lars's Avatar
lars
My normal response is that you can't flick the throttle in neutral and see the secondary airvalve open on a Q-Jet - the manifold vacuum usually does not drop far enough, and airflow is usually not high enough, to cause the airvalve to open under a no-load situation. However, you can slam the throttle to WOT and hold it there shortly (very shortly) and see the airvalve just crack open with an associated shot of fuel that will spill across the airvalve. I just usually don't recommend doing this, since rpm can get a bit high and it simply doesn't prove much: As long as the lockout lever is not engaged (and you can see this easily), the airvalve WILL open when you go to WOT under load - there is nothing that will keep it from opening.
Old Mar 22, 2004 | 11:28 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
i have seen Qjets that the top was distorted from over tightening the screws that the secondary air was stuck. see if it will open with finger pressure with the engine off :chevy
Old Mar 22, 2004 | 11:44 AM
lars's Avatar
lars
Default Re: help tuning quadrajet (clem zahrobsky)
:iagree:
To help tuning quadrajet
