Rear diff. question.
Old Apr 5, 2004 | 09:58 AM
JBR's Avatar
JBR
Default Rear diff. question.
Is there any difference between sb rear diff. and the bb rear diff. :cheers:
Old Apr 5, 2004 | 10:04 AM
Mr.Gearhead's Avatar
Mr.Gearhead
Default Re: Rear diff. question. (JBR)
NOPE! ALL the same... I don't believe there were many differences bewteen BB and SB Corvettes. Someone else chime in if I am incorrect :rolleyes:
Old Apr 5, 2004 | 10:48 AM
Gordonm's Avatar
Gordonm
Default Re: Rear diff. question. (Mr.Gearhead)
They are the same. The big blocks and high HP small blocks had caps instead of straps for the ujoints. Other than that they are the same. 65-79 rears are all interchangeable.
Old Apr 5, 2004 | 11:12 AM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Default Re: Rear diff. question. (Gordonm)
The big blocks and high HP small blocks had caps instead of straps for the ujoints..
I don't think there is any rime or reason on which got the caps. Also the pinion U-joint is bigger. My 75 L-48 with 165hp had the HD caps and bigger driveshaft U-joint.
Old Apr 5, 2004 | 12:59 PM
NHvette's Avatar
NHvette
Default Re: Rear diff. question. (turtlevette)
:iagree:
Why automatics get HD yokes ? Oh well ... just the way it is.
So, the only differnece you will find are in the pinion and side yokes ... (Ujoints).
:seeya
[Modified by NHvette, 12:59 PM 4/5/2004]
To Rear diff. question.
